Scottydoggs
I use sea foam in the oil all of the time. Was very successful at getting rid of lifter tick in more than one vehicle. It is a recommended use on the can, however you are only supposed to use a few ounces and for just a few hundred miles right before oil change. Read the label and use accordingly.
ive heard more lost oil pressure and now its knocking storys then i care to talk about when seafoam in used in the oil. its always when they drive it vs letting it idle for 15 minutes and doing a oil change. iirc s/f says to drive it a few hundred miles, and iirc they call for a third the bottle in the gas tank, third in the crank case, and a third in the brake booster line.
in this case he clearly used to much in the oil. just hope the pressure comes back.
there is a screen under the o/p sensor, it just might be clogged up good now blocking oil to the sensor. thus it reading low now. if you take that o/p sensor out, you can screw a mechanical pressure gauge in to it and fire it up and get more accurate reading of the pressure.
