Kpwweb
- Joined
- Dec 11, 2015
- Posts
- 771
- Reaction score
- 357
The key to testing fuel pumps is LOAD. Go up (or accelerate up) a very long hill. Accelerate hard from a rolling start, etc... The engine needs to demand a large quantity of fuel at once (or a large amount over a long period of time). The other key for the fuel pumps is heat. Apparently there is a batch, or batches that fail under heat and load. Mine stumbled horribly with both those conditions. Would run fine normally--normal acceleration, etc. I did have a stumble every so often at idle, but would state the truck ran fine otherwise.
But when I floored the throttle one day--wham! The engine bucked violently AND THEN took off. I repeated the test and it did the same thing. Still accelerated normally under "normal" acceleration. So the best way to test it I found is in a safe place, roll at 5 mph and then floor the accelerator and hang on--see what it does.
