TPMS question for aftermarket rims
rgosart
Be careful. The sensors are different throughout the years. I am not sure of the exact models, but the sensors that came with my 2016+ wheels did not work with my 05 Tahoe.
The sensors are fully functional, but my truck does not see them...
dnt1010
Tennessee
2009 Chevy Tahoe. I am not sure about any part numbers etc for new ones as Discount Tire supplied and installed them. These pics are of the old ones and I am pretty sure that these are original TPMS units. The pics did not come out very clear but there is a note on the sensor that states to change the stem and screw at every tire change. The units are 100% sealed so there is no way to just change out the battery. These were manufactured in the UK.
mijohnst
mijohnst
View attachment 239116 View attachment 239117 View attachment 239118 View attachment 239119 View attachment 239120
Thanks for taking the time to post these pictures. They're really helpful! I'm starting to wonder if I can just replace the stem with a rubber one from RockAuto. They sell those there. I need to get my TPMS modules out of my old rims to verify that.
HiHoeSilver
Away!
Chicago
You really should just change them if you think they're 15 years old. They typically last around 10 years.
Also, as @rgosart stated, model year matters. I forget what year yours is (you should fill out your signature). The sensors changed in 07+ vehicles. I THINK that the NNBS and K2XX trucks are the same, but don't quote me on that one.
rgosart
For the NBS trucks the AC Delco part number is 15114379. I do not know if you can put rubber stems on them. The stems that rockauto lists for these look a lot like the ones for the newer trucks. Not sure if I am wrong or if the parts listing is incorrect.
Before I changed my wheels, I had one sensor that was starting to come and go. Decided not to swap them to the new wheels and just buy new ones. I haven't done that yet, but that is my plan. It would suck to pay someone to mount and balance tires and then have to pay again to change out sensors. If you have your own tire machine, that's a different story.
Big Mama
Virginia
These are what I used in my 07 Yukon
ACDelco 13598771 GM Original Equipment Tire Pressure Monitoring System (TPMS) Sensor
just_heart_save._CB465530200_.svg
$ 24 50
& Free Shipping
mijohnst
mijohnst
$ 24 50
& Free Shipping
Thanks for posting this. It won't fit mine because I have a '05. It'll be helpful to someone though I'm sure.
mijohnst
mijohnst
Well, I think I found my answer and should have come up with it on my own. It was suggested to me by someone at Discount Tires that sees this often. Tape off, scuff and just paint the TPMS stem high temp semi-glossy black. He said it's what most people do in order to avoid the cost of new TPMS sensors and it's hardly noticeable. Anyway, I guess that solves my issue. Good info in this thread! Thanks for all the helped! I'll post pictures when I'm done.
wjburken
Eastern Iowa
If you have 15 yr old sensors my guess is you have a very high chance of needing to be replacing them soon so personally, I wouldn’t go through the hassle and just get new sensors installed.
mijohnst
mijohnst
I totally agree with you. I didn't want to have to go through this again so I ordered all new sensors. Hopefully they'll be in early this coming week so I can get started. Great suggestion!
csan2879
