I’m back with an Esky this time
Snowbound
Snowbound
Jim
Chicagoland (Lockport)
I got home from work around 1:30 and had a few minutes before my BIL dropped off my daughter. So I sandblasted the flywheel and brackets that hold fuel lines and wiring. Then I started painting when they showed up. 20-30 minute intervals is what I can escape to the garage for. Due to the fact I’m rushing, I didn’t get pics like I should. I know, I know, I’ll get some 2mrw.
I got the rear main seal and cover installed. I hated doing it without the alignment tool but I took my time and checked and double checked to make sure the seal was centered. I don’t want to ever see this flywheel again so I made sure the seal is gonna work.
But before I put the rear cover on, one of my trips out into garage, I pulled the factory plastic “barbell” (oil pressure diverter/restrictor) that is above the oil filter. It goes into the back of the engine and the front part blocks oil passage that comes off the oil pump and directs the oil down into filter. Then plastic barbell gets brittle and doesn’t have a machined fit which allows oil to bypass filter. So then you have non-filtered oil feeding all your major parts. Not good! So I replaced this plastic unit with a billet one that has much tighter tolerances and only something as small as 10-15 micron would be able to get past it. Filter is good for 25 micron.
Next couple rounds of garage time I was able to blow out the trans lines and run some flush thru them. After 3 cans and continuous blowing, I still have some metal shavings coming out. So I’m gonna work on running a pump in line and circulating it thru a filter to try and get the lines and cooler clean. I may just end up replacing the cooler. I just figured I’d try something first.
I promise, I’ll get some pics up 2mrw.
Snowbound
Snowbound
Jim
Didn’t get to do anything yesterday. By the time I was able to get out in garage it was after 8pm and I didn’t want to be working on this thing until midnight.
But today I started by trying to clean lines and cooler again. What’s better than pics? A video. Here you go. I’ll report back later with progress.
Here was filter after first 5 minutes of run time. Changed filter and letting it go for a good 20 minutes.
Sam Harris
20 minutes later, this is what I found in filter.
I’m gonna blow ATF out and then switch hoses to go the other way. I hope this cleans up. I don’t want to change the cooler. But from what I’m seeing here, it’s inevitable.
Damn that sucks man. Yeah, if you can switch directions of flow a couple times that might help. I’d try to keep going until you get nothing out at all. But may be inevitable like you said.
Probably gonna have to change the cooler out. Unfortunately I don't think everything is gonna come out in the flush.
Loving the pump setup! What kind of psi does the trans fluid normally run at? I'm sure it's more than what your pump can do. Could you fill the cooler with fluid and back-blow it with the compressor at a PSI a little greater than what the trans pumps at? Surely whatever may have gotten lodged in there from the normal trans fluid pressure would be dislodged if hit with higher pressure from the opposite direction.
Snowbound
Snowbound
Jim
Line pressure is usually 45-80PSI at idle. Can reach 300PSI at WOT. My compressor is good for 185PSI. I was thinking about adding compressed air on the discharge side of pump to help agitate the fluid but I didn’t want to make a mess increasing the pressure on the return side into the bucket.
I ordered a cooler tonight. Sum ***** is $175!! But it’s insurance. I don’t wanna be doing this again any time soon.
I thought it was around 60-80. Had no idea it could get 300! Oh well, that $175 is cheap insurance and peace of mind when not spending it could cost you 15 times that!
I took that little oem cooler off and put a tru-cool 40k in it's place that and a b&m pan and it dropped the trans temps way down I can barely get it to hit 180 beating on it in 100+ deg weather, normally it stays about 135 deg now. Before it was always running 190-220 or more
Snowbound
Snowbound
Jim
Got a link? Direct replacement? Or am I gonna have to change the fittings?
Snowbound
Snowbound
Jim
I did this on my truck. Ran 2 coolers, one has a thermostatically controller fan. Same thing, dropped my temps by 60-80* while towing. Also did a PPE pan and switched to Amsoil at the same time.
But I also changed the lines to braided lines and AN fittings. I don’t wanna do that to this.
I just bought another one for the 18 Silverado couple weeks ago, I think this is about the best price around still. I just used the rubber hose and fitting that are included with the cooler and clamped over the factory lines. I used a bracket to move the ambient temp sensor over a few inches because it kept telling me it was 125 deg''s outside because it was sitting behind the cooler, when i mounted the cooler I used some 1" stand-off's I didn't want it flush up against the radiator support. I originally went with a flex-a-lite but it's didn't do shit
https://www.ebay.com/itm/Tru-Cool-Max-Transmission-Oil-Cooler-40-000-GVW-Low-Pressure-Drop-LPD47391/322225882661?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
View media item 27546View media item 27547View media item 27545View media item 27544
this is the B&M deep trans pan it helped in part of that, it gives you an extra 2qt capacity, It takes about 3 months to get one they are always on back order nobody has them in stock, I am waiting on one for the Silverado for almost 2 months now
https://www.holley.com/products/dri..._accessories/transmission_pans/gm/parts/70392
funny when I linked that the shipping date was 12/18, i just clicked on it and it changed to 12/31 they cant keep these in stock
That's a nice setup.
Snowbound
Snowbound
Jim
I can’t bring myself to use rubber hose on a barbed fitting with a hose clamp for a trans line. I seen a buddy do it on a brand new trans and hose popped off and puked all the ATF out and smoked the new trans. They rebuilt it again because he said it just stopped working but I made him use hard lines and fittings. Shamed him into it really. I couldn’t imagine having my family loaded up heading up north and the line blow off. I’ve just seen too many things that can go wrong, go wrong.
But I like that pan. I may have to order one. Thanks for the links. I’m gonna see if I can find factory fittings to fit that cooler.
Sam Harris
Truth
varminpoolteam
