2007 Yukon Denali stalling
vettes980
@Bruce Mace How's your Yukon? Any recurrence of the issue since replacing the fuel pump back in early May? I am having the same issue and can't tell what my next move should be. Any information would be much appreciated.
Same issue. Limped home 14 hours today. As long as I was moving all was fine. Stopping for gas or anything else was a crap shoot if it stayed running. Had lean bank 1/2 P0171 P0174 that I thought was caused by cracked intake manifold vacuum line and replaced yesterday. Made idle better and gave a false assurance for my trip home. One stall required a floored pedal and continuous crank to get it to restart. Other time started up after it stalled pulling into parking spot and it sat for a few hours. After all that, I just kept the revs up when I had to stop or slow. Died again as I coated into the driveway. Anyone?
Get a cheap fuel pressure gauge and check your fuel pressure, should be around 60-65psi with just the key on and then should drop to 48-50psi with the engine running.
vettes980
Just got one and recreated the stalling. Fuel pressure is the same when working fine and in a stall situation.
No codes to speak of.
vettes980
I’m leaning towards the TAC motor in the throttle body. As I coast into the driveway it will stall, won’t restart until I hold the pedal to the floor and crank for an extended period. Once it restarts it’s like nothing is wrong. Will idle just fine, shut down and restart without issue.
HMM, ok could be different things then, you really need a scanner to troubleshoot the problem, but could be maf (mass air flow sensor), throttle body, map sensor, etc you need something that can read live data, not sure what you want to spend on it but a clone tech2 runs 300-350 on ebay, a cheap bluetooth elm device could read live data but wont do what a tech2 can. without at least getting some live data it's kind of a guessing game. @swathdiver have any ideas?
I'm with you, we're just guessing and throwing parts at it without the proper tools for diagnosis.
Whatever this is, seems to be pretty common though, 3 or 4 guys with it in the same thread.
kbuskill
NE. FL.
The way you describe holding the pedal to the floor and cranking sounds almost like the engine is flooded.
On these trucks holding the pedal to the floor and cranking causes the fuel injectors to be disabled so that you can clear the engine if its flooded.
I wonder if the evaporative emissions system is acting up and allowing fuel vapors to flood the engine via the purge valve???
thompsoj22
ok thx I will look into it so far the new fuel pump seems to have solved the problem crossing my fingers
im pretty sure your vehicle has no fuel return/pulse damper, the pressure is regulated by a pump module that varies pump speed as needed. It is soooo necessary to have the scanner running while your driving to isolate the problem to the correct system/component. If the new pump made a difference and it was the only component replaced in that repair i would "guess" fuel related. fuel pressure to ECM, ECM to module or module to pump. i love guessing with opm, but it is embarrassing when it turns out to be somthing as simple as a corroded/loose connector?
vettes980
I do have a live data scanner. Autel Maxicom 808 something. I did confirm that all the usual culprits were in spec while driving. I could recreate the stalling consistently and the procedure to get it restarted. Once restarted, it would restart without issue while parked over and over. I installed an AC delco throttle body this morning and made it to work without any stalling where it would usually stall once I pull into park. Not going to claim victory yet as one drive w/o issue is just that, one data point.
I’ve been guided through this by my ASE friend and of course from advice on here. Will update after a few more cycles.
vettes980
That’s exactly my thought and with all that has gone on with it, I suspect the TAC motor controlling the throttle body is out of sync or failing causing the butterfly to not work under idle. I had codes for the the throttle body when I bought it 1 year and 12k miles ago. I just cleaned it and the codes never came back. It’s always been in the back of my mind that I just prolonged its death. Cheap is expensive.
vettes980
I’ll find out tomorrow! blocked off the vacuum line from the evap canister to intake. Truck died again today on way home so throttle body wasn’t the problem.
vettes980
So I plugged the evap line going into the throttle body to rule out fuel vapor flooding the engine. I have a picture of it but I can upload pics for some reason. Same result. Stalled at the same point in the drive home and then again as I roll into the driveway.
I then took the gas cap off and drive another cycle and same thing.
What live data should I look for to rule out other items? When I looked at specs I was driving on highway, not during times that the truck usually stalls.
vettes980
Scanned ECU again and P0011 (camshaft position system performance) popped up. Not sure if a result from all the bucking and stalling or not. Was not a code that came up when this issue initially cropped up.
vettes980
Another drive cycle completed where I coasted in neutral for 5 seconds leading to a stall situation. Theoretically ruling out TCC and solenoid issue of the torque converter staying locked and bugging out engine when coming to a stop. Oil is pink, does not smell burnt and no apparent metal in it.
just wondering here if you have checked your battery cables and grounds? are you having any other power related problems like flickering lights or other weird stuff going on? I would record live data as you are driving and see what is happening as it occurs.
vettes980
I haven’t checked them. I haven’t noticed anything other than the Service Traction System lights randomly flashing on the DIC, but I have read that this has happened in other threads for similar situations.
AFAIK, my Autel MK808 will record live data, but only the screen that is currently up and visible. I can’t record say everything and then go back and review all different areas of the ECM.
BG1988
thou shall check voltages and ground ohms when trouble shooting... i would have the alternator checked and battery.
if the voltage dips below 11volts the engine will stall out
vettes980
Battery voltage is 12.xx when off and mid 14/low 15 when running. I will inspect grounds and alternator I will see what that process is to check.
BG1988
its a vvt code bank 1 (p0011)
bank 1 intake camshaft is more advanced than what the ECM has commanded it be.
When was the oil last changed? and how often
vettes980
Oil is 4.5k miles old in Mobil 1. Bought 10.5k miles ago 199k. Needs a change but was focusing on this issue first.
briannorris
