Woven copper wire for grounding
Tahoe97
On my 23 yr old 97 Tahoe, there are (were) several body to frame copper grounding wires that are an uninsulated copper weave. At least 2 of them are so old and corroded that they broke and are no longer making any ground connection. What kind of troubles might I run into if I don't find a way to re-establish those connections? Any recommendations on where to re-attach/re-establish such grounds?
wjburken
Eastern Iowa
You can buy replacement woven wire grounding straps or you can use any suitable sized wire with appropriate terminals on the ends to provide a ground. I would keep the color green so the next guy to work on it can recognize it as a ground wire.
https://shop.advanceautoparts.com/p...rEndextxoCKY4QAvD_BwE&store=3365&gclsrc=aw.ds
https://www.rockauto.com/en/moreinfo.php?pk=195509&cc=1061367&jsn=1106
Multnomah Falls
Military
Depending on where you are at and the amount of salt on the roads, you can go back with the weave grounds or like wjburken said, go with a green insulated wire of the appropriate gauge wire, like a battery cable, with the eyelets on each end and of course do the green color. You may have to get bulk cable and make your own length that fits and install eyelets at each end. If you do, do yourself a big favor and do not just crimp the ends on, get the ends that you not only crimp on but have to heat to melt the solder around the ends inside the eyelet. The braided strap would be quick and easy and they are inexpensive and easily available.
Multnomah Falls
Military
National Electrical Code
In the United States, the National Electrical Code (NEC) mandates electrical wiring color codes for the protective ground. The protective ground must be either green, green-yellow, or bare copper. “Green-yellow” refers to green with yellow stripes. For all other functions, there are no legal requirements. However, certain colors have been adopted as local practice and are recommended. Due to safety reasons, the use of a 2-wire ungrounded system is discouraged. However, the colors red (for positive) and black (for negative) follow the grounded system coloring code.
Typically the color black is listed as Neutral and not Ground. That would be a two wire system talked about above. The ground has also been said can be woven or braided copper wire as we talked about. I think Black or Green gets the point across.
HiHoeSilver
Away!
Chicago
Not to nitpick but shouldn’t DC grounds be black?
The black in a DC system is -.
If you really want to nitpick, a vehicle is an ungrounded system because it's not bonded to earth. We call them "grounds," but they're really -.
That said, I agree with black as opposed to green.
wjburken
Eastern Iowa
There is no national color code for wiring when it comes to automotive wiring like there is for residential or industrial wiring, save for the high voltage wires on a hybrid vehicle which are made very visible and are usually orange. Each manufacturer has their own color palette that they use. I recommended green as it is very much synonymous with being for a ground wire.
HiHoeSilver
Away!
Chicago
Or a reverse trigger....jussayin.
Black or bare is best.
Tahoe97
Tahoe97
Thanks everyone. It is tough getting old. The original copper braided cable just crumbles in my hands now. Need to establish some new grounds.
liquify33
Houston
I feel your pain, the one by the crankshaft for the ignition system broke on me recently also.
Brian12019
