04 Denali Headlight Inspection and cleaning
Sdp1234
Southeastern PA
My low beams are very dim. Today was the day to take them apart, clean them, and install new bulbs.
A couple pictures of the assembly’s
I’m worried about the flaking mirror material looking down inside the light
Is this what’s causing my problems.
If the chrome is flaking off the inside of your projectors, your lights won’t work well at all.
S
Sdp1234
Southeastern PA
Can projectors be purchased separately or do I need to purchase the complete assembly?
You’ll need to buy the whole assembly. Might be able to find some used ones in a wrecking yard or EBay that have real bad lenses that are all yellowed out and steal projectors from them.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I have an 02 and was interested in this and I looked and found only complete assembly listed at RA and GM Parts
I wouldn’t suggest painting the reflector part of any headlight, projector or regular reflector. In projectors especially the quality of the reflector bowl is directly related to the quality of the output. You want something as close to a mirror as possible with the least flaws. There’s no paint that will do that.
Noted.
05Single
afraid of the dark
Buy CB&D brackets for a retrofit. $55
Then get H1 bowls from theretrofitsource.com
Acme super mini H1 - $50
Morimoto mini H1 - $150
H1 halogen bulbs - $10 - $30
H1 HID kit - $30 - $150
Not only will you have new bowls with new reflective and non flaking chrome but you’ll have better output than you would even with brand new oem lights
S
Sdp1234
Southeastern PA
05Single, I’ll look into this in the future. Purchased Purde replacements and installed them. They were cheap and you get what you pay for. Much better than the stock with the bad reflectors but a lot off shadows.
I will keep my stock lights and look into the new bowls and retrofit.
The retrofits are a great idea and also the easiest retrofits out there, you don’t have to bake the headlights open like almost all the others. I completely forgot the stock Denali headlights are candidates for that with the brackets you can buy.
PNWMuseumman
Bow Ties Are Cool
PNW
Excuse my french, but how in the hell did you get the actual projector assembly off of the rest of the housing??? The projectors on my 02 are filthy, but hwen I took out all the screws it wouldn't budge. reguardless of how much I pried on it.. I finally gave up for fear of breaking it. Word to the wise, it is possible to clean it up "some" with it still attached, but it is a major PITA, and I still look at it almost everyday and silently curse those housings...
Many thanks for any help as to how you did this wizardry!
They’re held in place with Permaseal which is a *****. Google it. Heat helps a bit, prying helps a bit and you definitely need a good razor knife.
S
Sdp1234
Southeastern PA
I’m sorry but there was not a secret . Maybe it was easier because I already determined they were “toast” I pried from simultaneous points at the same time
S
Sdp1234
Southeastern PA
Will the new retrofits bolt into the purde lights I naught? They don’t have good light but they look much better than my old stock units
Into the purde lights ? They will only fit if your new lights have the same projectors as the stock ones. I know Anzo U-bar ones work.
S
Sdp1234
Southeastern PA
The new hids will have projectors so I guess that matters so that the adapter plates and everything line up?
S
Sdp1234
Southeastern PA
Finally going to do this... ordering later today. Any reason not to proceed with something like this?
05Single
afraid of the dark
I have zero regret . Anyone who has done this has zero regret
briannorris
