Cheap parts before off to scrap
Staggered 02
I went out to check it out I see the part that connects to steering box and other end connects to column about 12-14 inches long. how does the other part get removed?
If I recall correctly it slips into the steering column. If you remove the portion that attaches to the gear box, you should be able to slide the portion that goes into the steering column down from the engine bay side. If it doesn't come off, I'll take what you are able to remove.
I had actually purchased those pieces new for both my trucks but the shop chromed everything. They only should have chromed the side that interfaces with the shaft in the Engine bay. The plating chemicals caused the knuckle to seize.
Thanks.
HiHoeSilver
Away!
Chicago
HiHoeSilver
Away!
Chicago
Staggered 02
Yes sir that is what I am looking for.. That will be shipped to my house in Floirda, 32927. That is where I have full access to all of my tools and items needed to get this ready for refinishing etc.
Thanks.
dnbri512
