CHOO CHOO
BackPagePhil
Manheim, Pa
on second thought, how low was the coolant?
I put the half gallon I had left over in the Tahoe just now. It's drained that much since I topped them off recently.
those look like either the transmission cooler line's or oil cooler lines very typical for them to look like that they seep a little oil nothing really worry about and probably wouldn't even affect the oil level between changes. the oil cooler lines go up the drivers side of the radiator, the transmission cooler lines go up the passenger side.
Yeah, these are on the passenger side. I've noticed them before, but just seemed like it was more than normal.
I put the half gallon I had left over in the Tahoe just now. It's drained that much since I topped them off recently. Yeah, these are on the passenger side. I've noticed them before, but just seemed like it was more than normal.
as long as it's not going to freeze you can just add water until you can get it replaced, I think you said it was a short trip to work anyway?
CHOO CHOO
BackPagePhil
Manheim, Pa
Yep, 7 miles one way.
You can do it yourself. Not a hard job, plus you'll save yourself $200-300 on labor and parts.
True, and I do have off all next week due to work laying us off that week.
If that's the case, what do you all recommend for a replacement? Brand? Is there something better to upgrade to?
Kee Fuller
las vegas
just hit it with a car wash pressure washer then wipe it down, just don't spray directly on the electronic parts, I do mine about twice a year gets rid of all the grime and grease built up.
I got so much new electric parts under there now... lol
I think my radiator is cracked.
When I was a young man, when we had metal radiators, we used plain old kitchen table pepper to stop leaks in our radiators. Sealed up some pretty big holes on the side of tanks with pepper. Those are your transmission cooler lines, cost about $50-75 for both new ones, very common repair. I have to do mine and the engine oil cooler lines too.
63Blackseries
Canada
Those KM3s look great and sure they perform well. Would love a set but just don't NEED them, run KO2s instead. What kind and how high is she lifted? Oh, and lots of folks say the 900s are no good off road but what do you say to them?
I am on 2.5 / 1.5 leveling kit with bilstein 5100,
i love these km3s when aired down they went over almost every terrain except snow, will test it out when it starts snowing.
i had k02s loved them but the side wall tears easy when rock crawling, so far my truck and a gmt800 avalanche that comes along it hasn't let us down, it goes where all the jeeps and tacoma guys go.
Even some of them don't want to go places where i go still made it out alright i just need more clearance so ill be going with a bds 6inch lift with fox coilovers.
Have no idea, how would I find out?
You'd have hoses running from just above your oil filter to the radiator. It'd be an aluminum block with aluminum tubes coming off of it going upward then forward towards the front. Like this:
Otherwise, you'd have a factory block-off like this:
you would have 2 more lines that look very much like the ones you pictured yesterday leaking, except they would go up to the drivers side of the radiator, I think yours just has the transmission cooler so that radiator will work
$155 is a good price, not sure what they will charge for shipping rockauto is usually very reasonable they have 2 main wharehouse's one about an hour from me and then one over there on the east coast somewhere.
CHOO CHOO
BackPagePhil
Manheim, Pa
Yours is an LS optioned Tahoe right? Even some LTs don't have the external engine oil cooler and big fans and such, especially since she has 3.08 gears if I remember correctly.
Don't think I have that part. Yes, it's an LT.
So is there anything else I will need before I order the radiator? Besides fluid that is.
Driver's side and passenger side pics if that helps
j_jerry79
