Did a full brake job.
The front pads were worn to the squealer tabs and rotors were worn so much they had a ridge about 2mm high around the outer edges. I'm really disappointed in the cryo-tempered StopTech rotors. Maybe the Hawk LTS pads are too aggressive for them? Oh well, I got 50K miles out of them. I kept my original front rotors so I just had them resurfaced since they had plenty left above the minimum thickness spec. The rear pads still had a decent amount of life left, but I wanted them all to be new and matching. I pulled the rear rotors Tuesday evening to drop them off Wednesday to get resurfaced. Behind both rotors, I found the brake dust caked and wet around the seals. It hadn't gotten to the emergency brake shoes. So I added new axle seals to the job, which also meant a rear diff fluid change. I bought new bearings, but didn't change them since I found the current ones had been replaced before with good, USA-made pieces ("National" brand, and the same as what I bought) and had no detectable slack. I returned them to save the $93. I flushed the system through all calipers until the fluid coming out was as clear as the fresh fluid in the reservoir. I also cleaned and re-greased the caliper slide pins and greased all moving contact points with synthetic brake grease.
I started on it all Wednesday night after work around 8:00 and finished around 4:30 Thursday morning. Parts list is as follows:
Front pads: ACDelco 14D1092CH Ceramic, with stainless retaining clips, $23.79 from Amazon
Rear pads: ACDelco 14D1194CH Ceramic, with stainless retaining clips, $25.77 from Amazon
Front rotors: Stock resurfaced, $28.00 at local mechanic shop
Rear rotors: Stock resurfaced, $28.00 at local mechanic shop
Front drag-reduction clips: ACDelco 18K1025SS, $12.70 from RockAuto
Rear drag-reduction clips: Raybestos H6027, $4.56 from Amazon
Brake fluid: Valvoline synthetic DOT 3 & 4, $7.25 (x2) at Advance Auto
Rear gear oil: Mobil1 Synthetic 75W-90, $14.29 (x2) at Advance Auto
Axle seals: National 4762N, $7.69 (x2) at O'Reilly Auto
Rear diff cover gasket: Fel-Pro RDS55031, $14.29 at O'Reilly Auto
Total: $208.76
I went for a drive Friday evening to bed in the brakes. I did a fluid flush during the last brake job 50K miles ago and the fluid coming out wasn't all that bad, so I didn't expect much difference in pedal feel other than what the ceramics would bring. I did notice slightly more response and, of course, no squealing and no shaking/bucking when stopping. It's no performance braking system, but it's all I was aiming for this time around to scratch an item off my to-do list. Actually, it scratches off two items since the rear diff oil got replaced.
You don’t sleep?
You don’t sleep?
No rest for the wicked. lol
I get it when I can. I was screwed that particular day/night cuz the Tahoe was needed to haul a bunch of people around Friday night and Saturday so I HAD to get it all done ASAP. I worked much later than I wanted to so I got a late start. I came in, showered, made some breakfast and went right back out to go to work. I slept early and HARD after the trick-or-treaters stopped coming by.
Phase 1 drop: 2/3 consisting of McG spindles and coils. This also brought new loaded front upper and lower control arms since the ball joints and bushings were worn. Also, as part of the drop, are shorter front sway bar end links and DJM rear shock extenders.
Before:
After:
The drop ended up being 1.5"/2.375". I haven't figured out why only 1.5" in the front, but it's not control arm bushings binding and I doubt the coils are still unsettled. I like the stance, so I'll aim to keep this amount of rake at the completion of Phase 2 drop.
The rear rides much firmer than with the stock coils. I can't say for sure if it's the 3" McG coils or the suspension computer firming up the shocks because it sees the rear sagging. Phase 2 drop will include drop struts and shocks, DJM rear sway bar links, DJM rear control arm relocators and some "mystery" coils that I'm guessing would bring another 1.5-2" of drop and SHOULD be a softer ride. I have AirLift bags to adjust the firmness if they're too soft. The struts will be set for an additional 2" of drop on the passenger side and 1.5" drop on the driver side to level out the Chevy Lean. I have resistors for when I replace the struts and shocks to delete the Autoride. I'll swap the shocks when I do the struts but will try them with the McG coils so I'll know what was causing the firm rear ride.
A few shots of the process-
Gutted front:
Traced the slot in the Belltech alignment cam with silver Sharpie to mark where the frame slot will be elongated:
Used a cheap set of rotary rasps from Harbor Freight. Surprisingly, I did all eight slots with this one bit. It was pretty worn and cut much slower on the last few, but still did it. I also had to switch to a right angle drill because the angle grinder fell apart:
Elongated slot:
New control arm with factory cams:
I wanted to use the factory alignment as a baseline which would be lost with the Belltech cams. So I marked the positions of the original cams before I removed the old control arms. I also kept the original cams in their order after removing them. After elongating the slots, I reassembled everything with the old cams and turned the bolts to position the new arms per the original alignment marks. Then, I carefully removed one bolt at a time to reinstall them with the Belltech cams. The frame mounts were tight enough to keep the arm in position while I removed and replaced the bolts. With the BT cams in place, I marked them so the baseline would be maintained as a reference.
I cut a piece of angle iron to span the lips of the wheels, vertically across the middle, and stuck a magnetic angle finder on it to measure the camber before and after the spindles and control arms were replaced. The McG spindles caused a lot of toe out and about 1/2" total narrower track width. I've got the toe pretty close and it tracks mostly straight. The steering was overly responsive, so I dialed in some positive caster. The steering wheel at first was at about 9 o'clock and is now around 12:15, so I went a hair too far. But, it's completely driveable and the alignmnet will be fine-tuned during and after Phase 2.
Looks so much better. Any reason you went with McG spindles instead of Belltech? Did you measure the difference between the stock and McG? Seems to me all their stuff doesn’t net the advertised drop for some reason.
Thank you. Yeah, that fender gap and front rake looks way worse now that I can compare it to the dropped results.
They were part of a drop parts package I bought 3 years ago. I never heard or read of any cons about them other than the earlier ones (for NBS?) causing a small loss of turning radius. I definitely didn't lose any radius. Actually, it feels like it has a tighter radius now. I think I recall reading of BT spindles causing weird suspension dynamics on the NNBS, but I don't remember any specifics, it's been a while since I even had a reason to research. I laid them side-by side to eyeball for differences, but didn't actually measure them. Didn't think I had a reason to.
I just can't believe there's no info about this floating around. After these products being out for 15+ years, am I the only one that's ever measured to see what the actual drop is? I know so many people just throw parts on and don't think twice about it, if they even notice. I understand and accept that coils can and usually vary. But a spindle is a part engineered to perform one function and if it's designed and advertised to provide a 2" drop, then there should be no variances.
I agree. It’s a set amount, there should be no discrepancies. When I did the drop on my 02 I measured the spindles (Belltech) and the difference was an actual 2”. I didn’t measure the fender height because I went from 20” wheels to 26’s at the same time so there was no way to compare. The 20’s wouldn’t even fit with the spindles. I can only assume the drop would have been 2”.
As badly as I want to, I probably won't mess with it today since I'm still hurting from the other night. But, eventually I'll get into it again to replace the struts and I'll get some measurements then.
Had a shower epiphany last night: Maybe the LCA bushings actually ARE holding it up. I tightened the bolts with the full weight resting on them, but that was after having the struts unloaded for a few days. Maybe the struts hadn't settled yet and I tightened the LCAs at that unsettled height. What led to this theory is that I first measured a 1.25" drop, then, after some spirited driving, I measured that 1.5" drop. It's eating me alive that I can't just go out there and investigate. I'm even tempted to loosen the LCA bolts, have my chunky ass neighbor sit on the core support, then tighten them back.
wjburken
Eastern Iowa
I can see it now.
You: “Hey Neighbor, I need you to bring your chunky ass over here.”
Neighbor: “Sure, what do you need?”
You: “Your chunky ass, now sit right here.”
At least you can work on it still. I have no shop and we just got a touch of snow. I put the headlights back in the Silverado yesterday and that’s about all I wanted to do. Brrrr.
I'd go insane from anxiety and depression not being able to tinker even just for a couple of weeks!
BTW, I'm out in the shop now. lol
I just wanna test my bushing theory. At least I'll know they won't be in any bind at all. Just being careful to move slowly and not twist my back...
wjburken
Eastern Iowa
I know how it is. I’ve woken up at 2:00 in the morning thinking about a problem with a vehicle and had to go out and try an idea I had. Wife thinks I’m nuts when I do it.
I still tinker, it’s just on stuff I can bring inside. I just ordered another set of Depo headlights for the Silvy that I will do a complete build on- paint, retrofit, etc. Then I plan on pulling all the interior trim and removing the fake carbon fiber the PO installed on it and trying my hand at a satin black wrap. I also like the fact that we actually have 4 seasons here lol.;) My Malamute/Husky saw his first snow this morning and loved it.
Word. I stick to inside stuff when it's terribly cold out, like lower 40s and below. lol
The problem is a lot of my tinkering involves releasing of smoke and/or toxic fumes, so I have to have ventilation. Now that you mention it, I should get a roll of vinyl cuz wrapping my trim would be a great "winter" project. Looking forward to how yours comes out!
Aren't dogs a trip during that first cold snap?!
Oh yeah, I’m all about toxic fumes, just ask my daughter. I open up my doors with the furnace going full blast or light a fire in the insert. My neighbors think I’m cray cray like I’m sure yours do. And yeah, my dog ran to every patch of snow in the back yard and tasted them all. I’m gonna have to take him up the mountains this winter if we don’t get any real snow in the valley.
HiHoeSilver
Away!
Chicago
Quick, jerking motions will loosen you right up. Trust me, I'm a docter.
BadDaddy2003
