P0011 code and plan of attack
Denali2k8
Truck has an issue with surging power levels during light acceleration or constant throttle. RPM's will fluctuate a few 100 back and forth.
P0011 code tripped on highway 6+ months ago, but never again...until this week.
I have narrowed it down to prob being an issue with the VVT.
Plan: replace cam position sensor, the magnetic actuator, and the bolt behind it that goes into the motor.
Water pump needs to come off, so do I need gasket(s)?
Any thoughts on the issue and my plan going forward?
Dirty or the wrong viscosity of oil or oil additives can affect its performance. Part of the troubleshooting involves pulling the water pump and inspecting the wiring for damage and of course, using the Tech2 to command the CMP to different positions and see if it meets them.
How many miles do you have on your truck and it looks to me like a Denali? Which year?
Denali2k8
Denali2k8
Just under 100k miles, 2008 Yukon Denali
Oil is amsoil full synthetic 5w-30. Not dirty, still early for oil change.
randeez
south florida
fortunately, for me, i havent had to mess with the GM vvt components. my engine was pretty low mileage when i did the cam swap - i did still replace the cam bolt "valve" however, and installed the limiting block.
There really isnt much to the VVT system as a whole other than what youve mentioned along with the VVT actuator on the end of the cam itself. Sounds like you keep a pretty good eye on the oil level- Oil pressure look good? Im not sure how generic the P0011 code is, if a tech2 type scanner will pinpoint the issue a little more in depth.
at cruising RPM the code poping up makes sense, as that is where the stock tune manipulates the VVT and it would make sense that the valve and/or solenoid is failed.
under light acceleration it should be in it's "parked" position held by an internal spring... I will see if i still have a copy of the stock tune but i dont think it calls for any actuation low rpm/low load
i've never heard of it happening but it's possible the spring in the actuator has broken and the valve is over shooting the retard when its called for and can't hold the parked position but i would imagine you'd have a lot more and constant codes
Denali2k8
Denali2k8
What did u do for the cam swap? Obviously if the actuator and bolt valve and cam position sensor fixes my issues, it's not terribly expensive but im open to other options
randeez
south florida
Yea definitely, should be able to get it all done without digging into engine to much also.
Cam in mine is a 218/228 .600/.600 113lsa vvt cam , from Texas speed. Deleted the AFM lifters, pac 1219x springs
Denali2k8
Denali2k8
$50 local shop gonna diagnose the p0011 code before I dig in...
Denali2k8
Denali2k8
$235 later....cam position sensor was bad. Then is snapped off in the motor. So long story short it took forever.
I was also told my converter is showing signs of starting to go bad. Said like $1k to replace or let it go and eventually it will turn into a whole trans rebuild. Not sure of timetable obviously.
Denali2k8
Denali2k8
45-50 mph it shudders a little as it locks up? I didn't really feel it on my short drive home.
Sent from my Pixel XL using Tapatalk
Denali2k8
Denali2k8
Cam position sensor did not fix the issue. Debating replacing the actuator on the front next to the cam position sensor
JML07denali
Problem solved. I had an oil leak on the pan gasket. Took it in to get it replaced I also had them replace the oil pick up tube o-ring. That did the trick no more codes or service stabilitrack. The tech said the P0011 code was mostly likely caused by the o-ring. Hope this helps someone.
Denali2k8
Denali2k8
Baffles me how those are related and causing that kind of code from an o-ring
Denali2k8
Denali2k8
SO....p0011 popped up again, I am debating replacing the magnetic actuator. Any advice or info would be helpful. Seems decently easy. Remove water pump and swap a part.
yopinch
Greensboro, NC
Did you ever resolve your issue? I am having similar issues. My 07 Denali XL threw the P0011 code for the first time yesterday but has been almost stalling after driving on the freeway above 65 mph for the past month or so. It actually stalled in a traffic jam and did not want to restart initially. After 4 or 5 tries it finally restarted sluggishly. Once it stabilized, no code and it drove fine the rest of my trip. I really need to know the issue without spending major amounts of $$$ replacing a bunch of parts. I am in a new city and haven't gotten a "go to" mechanic I can trust yet. Any information you might have would help.
vettes980
Working through this exact issue you describe. Did you resolve?
vettes980
Did you ever resolve your P0011? TIA
brice715
