Well......they replaced a spark plug, said that all of the cylinders are losing compression. One is about 50% of what it should be.
So.....besides saving money, what are my options.
I can either
1: drop another engine in it and just keep it as a daily
2: buy a beater/daily driver and slowly work on the Tahoe
3: trade in and buy a new vehicle
I'm wanna keep this and run it into the ground, so it can become my learning vehicle and I can start doing what I want when I get something else.
Trade in value at excellent condition is $4500 on Edmunds for my area. Private is $4800-5000
Its not near excellent condition at all.
I'm just kinda torn, the new suburban was nice and not having to worry about anything going wrong would be a great peace of mind, but at the cost of a hefty payment which would put me at almost paycheck to paycheck, and I don't want that at all.
Sorry Phil; get another opinion or do the compression test yourself. Something doesn't seem right.
wendal
Dallas
Well, I've been trying to get my shorties installed since last Friday, and I have learned 1 thing. I am too old and out of shape to be crawling on my back on a concrete floor, on my knees for long stretches, and doing things that require I remove pieces from the engine.
I finally got the damned original manifolds of Monday evening. It is Thursday, and I finally got the drivers side header on, only to find that my stage 8 bolts are apparently TO LONG.
@kbuskill, did you have to use washers with your stage 8 bolts?
I added washers, and they still seem too long. I can't get the headers snug to the block. I am open to suggestions...
Problem number 2 is that the passenger side rear bolt is KICKING MY ASS. I cannot get that bolt started to save my life. Ivm too short to reach it from the top, and the space is too small to get my hand in there from the bottom. Frustration does not even begin to describe what I am feeling. Suggestions are welcome here as well.
One thing for sure. I will Not be doing anything else myself that needs a lift. Especially since I don't have one.
Sent from my HD1905 using Tapatalk
R3cord303
Posse In Effect
Oregon Valley
Have you tried re using the original bolts with the headers? I bought stainless header bolts from TSP and wound up not using them- I may be able to measure them tomorrow and see if they’re different from yours. I think they were shorter than stock because the mechanic that replaced my engine didn’t use them.
wjburken
Eastern Iowa
A couple thoughts:
What is the difference in thickness of your original header plates and the new ones and how does that compare with the difference in the lengths of your bolts? Your new ones look a little shorter in the pictures.
Might try and run a tap into the holes to make sure the threads are clean.
To get the rear passenger bolt on, might try taking the wheel and fender liner off and coming in from the side.
BG1988
I did pretty much the same with my 3 kids. My biggest gripe with the backup camera is that it gives you a narrow field of view. It’s like driving forward with blinders on. I have nothing against them
well it did save my butt from an insurance scam...
I pretended the"back up " camera was a dash camera and it recorded everything he said
other wise I was have been screwed they had 5 people inside and they all 5 claimed they had "injuries"
I think he was just trying to get out of his car payment as he totaled his Prius. he must have backed into a high up vehicle or something earlier in the week... as there was damage on the hatch door (no where that would touch the tahoe) as the bumper would make contact first before it would hit my tail light duh
kbuskill
NE. FL.
I didn't have any issues with my stage 8 bolts... they do have two different versions for our engines though... the standard length and a longer length... maybe you got the long version by mistake???
Don't give up, you will get it... they look great by the way.
wendal
Dallas
A couple thoughts:
Fender liner already off. It seems that the angle is a bit weird on the rear passenger bolt. I cannot get it started. I don't want to cross thread the bolt. What I need is likely an extra set of hands. If I put a bolt in one of the other holes to hold it, then it doesn't exactly line up. It needs to go in first, but I need a 6' friend with long arms to start the bolt from the top, while I hold the header from the bottom.
wendal
Dallas
Do you happen to know the part # for the shorter bolts by chance?
wendal
Dallas
I just found the part number, and I have the shorter bolts... The OEM manifold is thicker than that Gibson header, but it doesn't look like that much... I'm going to try putting the bolts that shipped with the headers in, I think...
have you tried a flexible shaft socket driver? they look like a wound up spring and bend in any direction, there not good for torquing anything down but are great for getting bolts started in impossible places, or a milwuakee cordless ratchet?
wendal
Dallas
I've got the spring extension. I tried it once, but it kept moving. unfortunately there's a lot between me and the hole. I'm 5'7" on a good day with the lighting just right, and I'm a big boy. Short arms + gut = can't reach. I've got a couple of tall friends I'm going to call to see if they can reach from the top. I'm just tired and want my truck back on the road. Luckily I have a third car, but of course, that's not the point...
Oh, and I've got a pneumatic ratchet that I've been using. problem there is that the head of the ratchet won't fit down in the space. Also, I'm scared that starting the bolt with a powered ratchet will cross thread...
CHOO CHOO
BackPagePhil
Manheim, Pa
Use thicker oil, take it easy on the old girl, and pray. And most important, TELL YOU YOU LOVE HER. EVERY DAY.
And a catch can helps too.
I vote towards replacement engine. Perhaps a running lowish mileage used one? And keep the old one to slowly rebuild and then swap back?
and yes compression test from another shop, and ask for the numbers. On my 1st engine at 226k when the lifter let go I was between 200psi on the highest and ~150ish on the lowest.
Talked to the owner this morning (that I've known for over a decade) he said cylinder 1 was at 55% compression, the others were normal. He said I shouldn't worry too much, but look at it like an early warning to start saving or looking. Said I could have a year or he has seen them last on low compression for over 10 years.
I need to find another shop that I can trust though.
On the thicker oil, should I? What should I use?
I figured I'll replace the spark plugs every year, what's it gonna hurt besides losing a few doll hairs.
I don't really get on it that much, I drive 7 miles to work everyday so I only put at most 14 miles a day on it.
I do need to get the cluster lights working though. I never got it fixed. Just the light that shows the odometer and PRND123 went out. Everything else works fine. Said it won't pass inspection because they need the mileage....lol.
kbuskill
NE. FL.
They came in a bag that said Kooks-106
(10) 8mm- 1.25 x 25mm
2014 Corvette C7
Stage 8 part number is 8900
The longer bolts are 8900B and they are 30mm long.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Yo bud do you still have the inner fender out? Can you get me some real good shots of the firewall behind the pass tire showing the heater and AC lines running to the back?
St. Louis
What gasket are you using? Some are thicker than others
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
I can either
Engines are plentiful and therefore relatively cheap. Source you one and reseal it and maybe even AFM delete it while it's out. The LS platform is easy to work on once you know a few key points so it makes a great "learner". Being intimately knowledgeable of the engine will be really handy for any future servicing. Consider yourself fortunate to have a decent head notice instead of suddenly having a blown motor and in a bind to jump on the first replacement you come across.
Did they specify why would it be losing compression? Maybe the valves are just cruddy and not sealing so set of refurb'ed heads would fix it. Like the others said- get a second or third opinion.
JamesinAbilene
