Adding/enabling tow/haul mode
Blackdrag450r
I am bringing this back from the dead to help others who search. You can indeed buy just a shift lever with tow/haul and plug it in. Just did it on my 2012 ppv. Works great and no reflash necessary. Also buy a cheaper shift lever from a silverado instead of the leather wrapped one that seems to be the only one that comes up when you search, no matter what trim level. The pn I bought was
25807851 hope this helps someone because it is hard to find an answer on here.
1BADI5
DMV
Bonus points for you my man.............F$%K me, something else to buy now LOL
safe to assume the install was a couple minute job since the wiring was already present for duty? Hopefully, this stands true for the 2010 PPVs
1BADI5
DMV
25807851 - $78 on Amazon
I guess I will be adding this to the list for Friday Mod day
Kee Fuller
las vegas
I did the same about 2 months ago. Theres a guy who sells em on here every now and then
1BADI5
DMV
Ordered mine last night, should get it tomorrow
jz57
I have a 2007 Tahoe 2WD PPV with a 4-speed transmission 4L60E. I have some question about this budget upgrade:
1) Is this plug & play upgrading, like DIC butttons?
2) Does the new shift lever activate Tow/Haul function and turn on Tow/Haul indicator on cluster panel?
3) When the "+" or "-" button on the NEW ***** lever is pressed, does the transmission shift up or down?
1BADI5
DMV
J - not sure.
I know my 08 LTZ had tow/haul mode. But the "+" & "-" for manual mode was only offered on the 2010+ models with the 6L80/6L90 transmission
But you could always try, if it doesn't work you could resell the item on here
Kee Fuller
las vegas
Yes
Yes
Yes
I have 2013 ppv so all of that works
ATLPPV
NC
From what I've read the 4L60e's won't work with the +/- like on the 6L80e's.
Does anyone know if there's a leather wrap version WITHOUT the chrome on the end? I have a full leather (no wood) heated steering wheel and want to match but don't really love the chrome tip on the end.
HiHoeSilver
Away!
Chicago
I have never seen one without the chrome.
madmanjustice
Yes
Yes
Yes
this is good to know. I have a 2013 as well and picked up a shift lever and steering wheel from a Burb to put in mine but have not gotten around to it yet.
and on an slightly related/unrelated topic. i just realized that my 2013 Ford E350 shuttle bus has tow/haul on the shifter...lol
1BADI5
DMV
Well time to haul some ass then lol
1BADI5
DMV
Got mine this morning and installed it; works perfect.
All you need is a T30 Torx bit and a small screw driver to pop the harness clips
Hodmjstone
