Help What's This Sound ????? VIDEO
Nap73
What's up guys.
I need some assistance here.
tried to use the factory remote start this morning and it made this noise and did not start.
Got in the truck and it started right up.
2007 GMC Yukon XL 2500 with 204k
Nap73
Nap73
Started making this noise a few days ago if that helps. It's intermittent though
wjburken
Eastern Iowa
What's up guys.
Almost sounds like your starter isn't fully engaging your flywheel with the remote start but is when you turn the key.
did you post in the wrong section? 07+ def do not have a fan shroud or shouldn't anyway, the first noise kind of sounded like a fan hitting something maybe 2nd vid didn't have the same noise
Nap73
Nap73
Yea I posted it in the wrong section. It’s an 07 in the 14 isle. On the plus side it’s a 2500 so hopefully the forum Gods forgive my transgression.
The first and second video are definitely different noises.
The belt chirp kind of noise started first a few days ago. But again it’s intermittent.
I replaced the alternator yesterday and the belt is new.
Have no idea what the grinding noise is. That was the first time it happened. Was able to get the video because it kept going. I guess because of the remote start
Have to take a long ride in the am so want to get whatever it is fixed.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Sure sounded like the starter gear was not fully engaging the flex plate on the first noise. Plus on the second noise I thought I also heard a slight bit of the same type of noise but only for 1/2 a second before the starter drive did go ahead and fully engage the flex plate and cranked the engine.
Nap73
Nap73
Low voltage to the crank circuit from the remote start module. Didnt engage the bendix firmly enough.
So the issue is with the remote start module.
Not the starter?
What about the 2nd video. You have any idea what that could be.
Pain@thepump
sOuL-CaL
Please take your time when making your video there's no rush. Especially if you're asking for someone to pin-point a noise. Also a brief description of noise pitch could help too. ie. the high pitched squeak/squeal, the low thud, the humming of air, whistle near manifold etc etc. Those are just a few ideas. Best of luck.
Not the starter?
The problem starts with the remote start. If in fact that is the problem. The further damage is done to the starter drive and the flex plate as a result of the remote start low voltage. That grinding is happening when the teeth of the starter drive gear and the teeth of the flex plate do not synch ad they grind metal.
thompsoj22
the first vid sounds exactly as stated above, the bendix is not driving far enough to engage the flywheel. the second vid sounds as though the bendix is not withdrawing quickly enough from the flywheel after the engine has started. the duration of the first vid is enough to have "fubar" your starter gear and or the flywheel in the area it did not engage. pull the starter, the gear will be damaged, rotate the flywheel, it will also be damaged. throw a starter at it and hope it is simply a bad bendix drive. $100 at oreilleys. the next time you turn the key it should be with a new/reman starter allready installed. the sound in the first vid is pure destruction.
Nap73
Nap73
Im going to do the starter today. What brand do you think is best? Readily available I can get
ACDelco reman $135
Duralast gold $159
O’Reilly’s around $100
If I wait a day I can also get a brand new ACDelco from the dealer $288 plus tax.
If you can wait you can get a new AC Delco from Rock Auto for $158.79 plus shipping.
You can get AC Delco from Amazon with free shipping for new #3371033 $183.02 or AC Delco reman for $121.99 from Amazon
Make sure you have a way to move the engine around and inspect the teeth of the flex plate when you remove the starter.
Nap73
Nap73
The one from rock auto I’m pretty sure is a reman.
I’ll check amazon though. It comes direct from ACDelco ?
Thanks
Yes, AC Delco is direct to Amazon and the new price at Rock auto is what I typed in here and has no core charge. Believe it or not the reman one from Rock Auto is more expensive and that is why I did not even type in that price.
Nap73
Nap73
Yes, AC Delco is direct to Amazon ad the new price at Rock auto is what I typed in here and has no core charge. Believe it or not the reman one fro Rock Auto is more expensive and that is why I did not even type in that price.
I just called My local GM dealer. The exact replacement starter is ACDelco # 323-1637 which is a higher output than the one from Rocauto & Amazon.
When I do a search for 323-1637 at Amazon it comes up for $283.00 AC Delco.
It also comes up with the GM number of 89017844
Bentley95
