Pick Ups/Tahoe Rear Disc Conversion
305Tahoe
hey Guys im just about done with the Rear disc conversions .Compatible with GM 1988-1999 4x4 pickups and 1990-1996 4x4 SUV's with light duty six lug rear ends and 10" drums. It will work on both 1/2 ton GM corporate 10 bolt rears with six lug axles and light duty 3/4 ton 12 bolt rears with six lug axles
as of now the Kit is as Follows
2 New Disc Mounting Brackets
2 New Rotors (11.6")
1 New set of pads
2 Used Calipers
2 Used Caliper Brackets
2 Used Brake Lines
All Mounting Hardware needed for Conversion
At this time ALL kits are for Use with NO E Brake Cable, im trying to find an Alternate Caliper as Most Kits Sold out there Use older style El Dorado Calipers wich I dont Personally like..
AS you all may know there is some Kits out there For Sale , so to Keep up with them I will OFFER 90 Day warranty on ALL USED PARTS>..Including Postage
total Shipped to anywhere in the Continental USA $349
I will have some pics of towards this coming Week , just trying to See who's Interested..
Ebay PowerSeller (780+ Feedback )
thanks
Julio
p.s.
any questions PLEASE Feel Free to Pm me or email me at
[email protected]
Paypal Certified and Verified
fyremanpat
Fyremanpat
is there anyway to fab up a parking brake? I couldnt pass an inspection without it.
305Tahoe
as of Now no. The kit has been designed to work with a bigger caliper than the One with Ebrake capabilities
haks310
Got LEDs?
SoCal
Why only up to '96? Shouldn't this work all the way to '99 models?
Only 10" drums? I know most are 11", should still bolt up?
What type of rotors and pads are you using?
305Tahoe
Prostop rotors
over counter pads..
typo 99 not 96
AtomicHoe094
Atomichoe094
cleveland, OH
Could i work something out with you for just the brackets, calipers, and lines? Ill buy everything else for 2wd 5 lug conversion? What kind of calipers do you use? like are they oem or what>?
305Tahoe
Everything Beside brackets is Oem (lol)...
Regarding kit.. I might be able to work on the price with out rotors and pads, but I cant promise you much as I purchased a LARGE quantity of rotors and pads, thts why the kit is fairly low in price as it is ..
AtomicHoe094
Atomichoe094
cleveland, OH
what did the calipers come off of to work for the rear? is this a stupid question or am i completely oblivious?
305Tahoe
HEY Remember there is no Such thing as a STUPID question... If you dont ask it that is Stupid...
I will have part numbers later on this week as soon as I have everything "On Paper"....
Did it on a buddys truck on friday , as I didnt wana run the risk of being with out a Truck thinking it was gona take longer.. it took me a little over 2 hours..
Complete swap should not take the average Persone with Hand Tools Longer than 4
haks310
Got LEDs?
SoCal
Think the S10 calipers worked, so it might be those. If it wasn't for the parking brake issue I would of picked a kit up.
Should work for either, 10" or 11" drums, right?
96ProCompTahoe
IN
sounds like a really good price, i have a kit still waiting to be put on in the garage, or i'd hit you up for some parts.
branndon_b
Lake Charles, LA
not trying to threadjack, just figured i'd get some good opinions in this thread. would it be any easier to do a used rear end swap with disc brakes? or would it be too much of a pita to get it to mount up? i know that may be an option if you wanted to go lsd and get a 3/4 or 1 ton rear end and go 6 lug, change the front hubs/discs. didn't know if it was just too much hassle. it is expensive to go to the disc conversion, i've looked myself. for that price you could almost just swap rear end/front hubs and get 6 lug (if you wanted) and disc brakes. like i said, wasn't trying to threadjack, was just curious and saw some informed opinions in this thread. sorry if i stepped on toes. branndon
305Tahoe
My toes are FIne....!!!
for $349 youll probably find a Disc Rear end But it wont be Posi or anything of that nature..
this kit is for 6 lug Only .. Its fairly simple swap compared to a HEAVY Rear end swap , wich you still have many Variables to consider...
1. Gear Ratio
2. if its NOT Posi or a Locker WHY Bother
3. COST for a Posi or LOCKER
4. Need Help as 1 Person ( average person working out of there house) Will have DIFFICULTY Changing alone
5. If you have it out Might as well Rebuild the Rear End, Unless Prior owner is Yourself Milleage on Rear end is UP for Grabs.
6 Keep your Rear End , Swap it out to Better Bracking Disc , Better Looking in just a Handfull of Hours......
branndon_b
Lake Charles, LA
oops. i meant a posi. said lsd. oops, maybe too much "lsd." yeah, this was written from a 5 lug point of view, seems there's lots of options in 6 lug for wheels and such, just don't know if it's worth it to do all that. and you do have a good point about mileage on rear ends. didn't even think about that. but a posi sure would be fun, discs or no discs. :)
branndon_b
Lake Charles, LA
another question, do you need any proportioning valve or anything if you go from drum to disc? haven't done a whole lot of research on that subject, was just curious.
305Tahoe
To be COMPLETELY Honest , I have heard both sides...
The truck I installed it on Does NOt Have it, and has had a few hundred mile on it with no problems..
I have also done Rear disc conversion on S10 Trucks with NO Prop valve and have not had any issues..
branndon_b
Lake Charles, LA
well that's good, i haven't looked to see if there are any orifices or anything that come with the aftermarket kits or not, was just a checkin. thanks for putting up with my silly questions.
riviera rider
got any pics of the kit? what is exactly included and are instructions included? i may be very interested because im planning on redoing all my drums/shoes/brake kit in the back and would be pretty much smarter to just upgrade it to discs since im running the 28s this spring
anyway to tell me what the rotors/calipers came off so i could just get some drilled/slotted ones with some high end brake pads and you just charge me how ever less for not taking the pads/rotors?
SuburbanPassion95
