2008 Yukon Denali, 135k miles, part 2!!
T
tgui
Engine cleaned up. Wiring fixed. Rest of exhaust prepped.
T
tgui
First fire up. Major exhaust leak. Proper video later.
ivin74
05 NBS Nali
Htown, Texas
Can you post some pictures of the headers from under the truck, I would like to see what the cats look like.
T
tgui
I'm at the boring parts now.... Those raybestos rotors still look nice! Oil change, tire rotation etc next. ****.
T
tgui
I got a bug up my butt last night and rotated the tires, finished off other misc, and took her for a drive. Not bad!
This morning I drove her to work. It was fun seeing people freak out at lights when smoke was coming out from under my hood as various oils were burning off
:alone:
I think these headers are close to equal length. At idle a bit more rumble, cruising its just a normal quiet Yukon. Flooring it she ******* screams though. Not like a rowdy V8 because of the EL headers. I'll get a vid eventually. It sounds good though.
Smiley3303
Minot, ND
Waiting on the clip! Had shorties on my Ram and they were nice but the 6.2L sounds way better than the Ram ever did if I am being honest with myself.
T
tgui
I personally think rams sound great.
With these headers its less rumble and more howling scream. It strange, but cool. I had a 500hp Subaru STi. When I went to EL headers the rumble was gone and more scream.
Smiley3303
Minot, ND
It had a nice bite the stock muffler on my Laramie was pretty tame. Those trucks have tons of manifold and manifold bolt issues so that is why I did headers. I haven’t had a need for headers on my 6.2L yet but like them!
T
tgui
Side effect to these headers, my drivers floor is heating up! The cat placement is much further down than stock and right under the floor. There isn't any heat shielding there.
I ordered some DEI heat shielding with adhesive backing. Its weather proof so I'll just place it right above the cat to see how it helps.
I wont be wrapping the header and cat like in this pic though
Too close without any shielding
T
tgui
Got the thermal pad and everything all taped up. I went for a drive, not breaking the speed limit of course, and the floor was just ever so slightly warm. Big improvement so far.
Side note, I'm damn impressed with the fit and finish of this kooks header setup. No rubbing, no leaks, still looks ok after a few heat cycles
The pad pre cut to test fit. It's 10mm aluminum with fiberglass pad and adhesive back.
T
tgui
Emissions time. Wish me luck! One failure allowed for passing.
Bwaldron
