Front & rear floor jack lift points
Incognito
Colorado
So I'm sure this has been asked before and that perhaps it's common knowledge to some, but I've been unable to find a solid answer through a search. Essentially I'm just wondering if it's safe to lift the front end via this cross member. I've done so several times now and have not observed anything unusual. I've also lifted the rear underneath the differential. Is that safe to do as well or am I totally wrong?
Tozan
Overlander
Yavapai Arizona
Same here. I try and avoid any kind of lumber between my jack and the frame. I bought a high-lift jack so I can get my vehicle high enough.
I agree I also avoid lumber at least nothing bigger than a 2x4....
Where can you put a Hi lift jack on a Tahoe / Yukon??? I have a hi lift but, I also have steel bumpers front and rear. However I still don't use the hi lift because the frame flexes and the bumper will crack the tail light. I have hooks for the wheels but, it would take and extreme reason to use the hooks on my cast wheels too. So admittedly my hi lift never gets used.
wjburken
Eastern Iowa
Let me clarify. By High Lift, I mean a floor jack with an extended lifting range like the red one in the photo below. I am not talking about a farm jack or off-road jack. I apologize if I caused any confusion with my choice of terminology.
https://www.ebay.com/itm/US-4-Ton-E...524682&hash=item5d904ff05a:g:8gsAAOSw0AFcwYHF
jkavros
