Paint Prep / Body Work Tips
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
That's awesome, what part of Canada (it's a big place). I have traveled quite a bit up there and used to live by Kingston, Ontario. I'm down in Arizona right now, lots of my clients at work are form Canada though. They help pay for me to tinker with cars lol
I'm curious I ordered my regulator. I also will need another gun (or nozzle) to spray primer. I thought I'd just get a cheap gun for primer. Any thoughts on that? My current is that Devilbiss GTI it has a 1.3mm tip.
Love your truck. So many of us are doing the same thing. I didn't think anybody rebuilt trucks of this vintage yet. It's been a blast. I redid a camaro years ago, and traded that for a vette. Both are nearly impossible to work on (due to space). I can easily take this apart and do whatever I want with it :) Super fun and easy to work on these truck.
SteveB
I'm in Wainwright , Alberta. I would love to be down there , winter is just around the corner , compared to here building cars is a bit cheaper down there.....lol.
Yes get a cheap gun for primer. When you go to the paint supply place ask what size of tip they recommend for the primer. I use a 2.0 tip in my primer gun.
Yeah these trucks are much easier than my 98 Camaro by a country mile.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Ha, I'm typically up in your neck of the woods each year around this time. I spend a couple weeks in the back country. last time I was there though was 2016. I think we took 13 through Saskatoon though. Cannot remember for sure, otherwise we went through your town :)
I dumb, so I got the gutter taken apart. I can easily pickup a couple of pieces of the rubber trim from junkyard. I seem to be completely missing one. However, you mentioned double sticky tape below. I have body molding tape but not sure that's the same thing. This seems to be foam backed, and you mentioned it having a sealing property? Do you know what kind of tape this is?
SteveB
That is 2 sided tape. It has no sealing properties , you need seam sealer. It is a caulking made for sealing joints , ask at the place where you got you paint from they will know what it is.
Next time you make it up here , have let me know.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Sweet thx :) I will ask at the paint shop.
def let you know next time I am up that way.
Curious what brand of cheap gun works fine for primer. I will prob order off amazon cause am lazy lol
Sent from my SM-G925V using Tapatalk
SteveB
Anyone really. When I bought my new base gun I used the old one as my primer gun....lol
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
My process is evolving and I am moving faster. I hope to prep whole truck within next couple weeks.
1. Currently I take a panel,
2. Wet it down,
3. Block sand with 340 in cross hatch patern
4. Dry panel and find blemishes.
5. hand sand blemishes with 220
6. feather out blemishes with 340 by hand sanding
7. Switch to dry sanding with 340
8. Look for spots i missed and sand them by hand
9. Whipe panel with damp cloth and continue sanding until entire panel is sanded.
10. Grab scrotch bright sanding pad and hit up edges I missed.
Curious, some of the edges refuse to feather out. I think the sanding powder is bilding up in them as i sand and keeping me from knocking down the edge. Any tips? Or is this just always solved with high build primer?
See picture below... I cannot get this edge any better. Oh and for fun the face in my door.
SteveB
The primer will take care of it. I would cut out steps 2 and 3. No need to wet sand. Just sand the worse spots with your 220 , block panel with 320. Prime any area that needs it. Sand primer with 320 , spray paint.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Awesome I like it. Even faster yet.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
On to more questions lol So my overall plan is to disassemble the body. Remove doors and panels to paint them. Partly because truck has 235000 miles on it. No rust, mostly free of dents, however paint shows it. There's spots inside the door jams, and on inside face of doors where paint has rubbed off to metal (pictures below). Also I've taken doors apart and off before so not intimidated by that part. Just never painted them.... I'm trying to picture how process will work with painting.
1. How do you secure door for paint? On sawhorses?
2. How do you spray both sides? I'm kind of picturing the door laying flat. Do you have to finish one side then go to bottom side? Or do you prop door up somehow to get both sides at once?
Any additional tips? Or perhaps there's an easier way to touch these bare spots on doors and door jams?
SteveB
Being your truck is black , just lay the door flat on saw horses. Paint the inside first , the when dry flip and paint the outside. When painting the outside be sure to back mask the inside from overstay.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I learn more only to have new questions lol
1. Dandruff and white edges. I am assuming this is delaminating clear coat and muat be knocked down? Some areas I am nearly to metal and it still persists?
2. Orange peal? I keep sanding and I have little pockets catching powder from sanding? Do I have to knock that flat?
3. I found an electric 5" DA palm sander at walmart. I am woundering if this will work to prep my hood which is nasty to say the least.
SteveB
The dandruff is clear that is just of the what you have been trying to sand off. Yes orange peel needs to be flattened out , after you sand the panel with 320 , take a red scotch brite pad and go over the panel . It will get the last bit of shine from the paint. Yes that sander would work.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Ended up finding a sander on amazon with variable speed so snagged it.
I took it a d hit some of the pesky dandruff areas with it, and a 320 gritt disk. It knocked em right off but I think I will have to re blcoksand those spots now. Very tricky to use unless pannel is flat (at least for me).
The sander didnt come with a soft interface pad. I wounder if I should buy one of those? Maybe I could do more of the sanding with it then and block after?
I also marked what I am cally factory orange peal. I am assuming that needs to be knocked down till isnt shiney anymore.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Making progress :) Few questions:
1. I'm using softened water to wipe sanding dust off. I'm curious I saw somebody on Youtube use, distilled water, rubbing alcohol and vinegar mix to clean as it prepped car. Does that work just like grease and tar remover? Otherwise what do you recommend. This dust is a PITA.
2. I'm getting close to starting on the little body repair... Have a half dozen or so door dings to fix. I bought Kombi SPOT putty. I'm assuming I spray etching primer first to seal metal, let dry, then do putty, let dry and sand, do 2k primer, and lastly sand with 300grit for color coat?
3. I have some stupid protective plastic on rocker arm. I want to remove that, sound down outside of rocker panels so they can be painted as well. Will paint them with Raptor Liner. How do I remove that dumb plastic tape. It's pretty stubborn.
4. I a few people come to my door to do bible study. The gentleman that came last time built hot rods. He recommended also doing a seal coat prior to color and clear. What do you think?
Tupapi
