SteveB
Painted my door speaker grilles. I used a high heat engine dark grey metallic color.
SteveB
Did you strip the old paint?
No used scrubbing bubbles cleaner and a red scotch brite to clean them , rinsed with water real good , blow dry with air , applied paint , then used a heat gun to cure it a bit. Let sit for a couple of hours then installed them. No need to try and remover the factory paint , would be more hassle than benefit.
Woodblocker55
Ok now I have 5 of these I have to deal with. I'm thinking of stripping clear coat off sanding the deep pits if needed 600-1200 grit . Then just polishing aluminum to a killer shine . Paint the inside part inside spokes with grey like they are now paint the back.. then just put like 5 coats of good grade wax on front polished parts.. and once year touch them up. Because I know if I clear coat and it goes yellow and just peel again . Any pointers to make easyer .
Let me know ..
Don't forget I'm in the salt belt .. Minnesota
Sent from my LGL84VL using Tapatalk
treehan77
TYF Fiend
Crestview, FL
Let me know ..
Too much work just find newer ones. I got the Acura rims I put on my accord for $220/set nearly brand new. And the wheels on my Yukon FROM THE DEALER with brand new tires for $700.
Big Jim
