Center console
Bamajake95
So I just bought a flow through center console for my 07 yukon. However the vehicle I got the console out had the rear entertainment system and all that crap, which I do not have. I was wondering if someone may have a part number for the blank/pocket they used for the back of the consoles. I dont want to have something that will serve no purpose and be inop once installed.
Sent from my SM-G960U using Tapatalk
Bamajake95
Bamajake95
Not the correct color, but is this what you are looking for?
Color will be black but yes. That is essentially what I'm looking for a had someone tell me though that they make that piece that removes all of that and is just a blank. But I have tried every way of searching for it but to no avail.
wjburken
Eastern Iowa
Interesting. Not sure I have ever seen a center console without having at least rear A/C controls.
Bamajake95
Bamajake95
I havent either. Im just solely going off of someone else's info I may be hunting a unicorn or something that does not exist. But that piece you posted is the closest thing I have found.
adventurenali92
Big Bear Lake, ca
Try searching for a console piece out of either an LS model tahoe or SLE trim level Yukon. I think the center consoles on those base model trucks do not have anything on the rear of the console. And would have a blank bezel that sits there. Have you tried the online gm parts source? Most times you can search through any trim level truck and get part numbers
Bamajake95
Bamajake95
I have been on there but havent cover all the bases as far as trim.
PG01
Up here to the right
golavaman
