the_tool_man
Upstate South Carolina
How did you get the smoke (from party smoker) into the EVAP port on the motor?
Ok, I meant, how did you get the smoke from the machine into the car, I reckon shaping paper into a cone and tape and then into a hose and on from there.
I had a small plastic funnel that worked. I just used electrical tape to hold it all together.
Sam Harris
Hooked up the tech2 and inflated the shocks to 18psi I will let it sit a while and see if it changes, I sprayed soap/water all over don't see any bubbles so far
***edit only been 10 minutes lost 4psi already but can't find the leak :mad:
Don’t like
probably just bad luck on my end, I haven't heard anything bad about them which was why I chose it as well as the price and warranty but the dorman has a lifetime warranty as well, I might just keep the replacement arnott they send me as a spare
PG01
Up here to the right
Ohhhhhh, you have my luck...... alllllll baddddd
I just need heavy duty stuff, I tend to break things, when I went to drop the pump to check for leaks one of the mounting bolts was snapped in half, other than that I don't know how I could break the pump I was suspicious of it when I put it in because it would pump and then seemed like it released a lot air thru the valve instead of just a quick little burst.
HiHoeSilver
Away!
Chicago
Maybe bad from the start then...
MTN_KDA
