01 Yukon SLT, how do I tell if it's Bose or No-Bose?
St. Louis
Thinking of replacing the head unit on our '01 but need to know how to tell if it has the Bose option.
I have Onstar, although it doesn't work because way back when they switched to a digital system they said it couldn't be converted.
It has the CD player with the tape player seperate and below the 12v outlets
I have a rear subwoofer
No steering wheel controls
I'm looking on Crutchfield and it gives the following options:
-with Bose and Onstar
-with Bose, without Onstar
-without Bose, with factory sub
-without Bose, without factory sub
Also, if I don't have Bose, is there still a factory amp? The rear sub stopped working and the sound coming from the door speakers has no bass.
What are the RPO codes for the different options?
if you have bose it will say it basically everwhere, speaker grills, tweeter grills, and on the radio face (usually), 01 should have a amp behind the glove box
gooffeyguy
St. Louis
If it's not Bose would it still have an amp somewhere?
Trying also to figure out why there's no bass and why the rear sub has seemed to stop working
I'm guessing it's not Bose, doesn't say it on the head unit
gooffeyguy
St. Louis
Thanks, I'll look after the wife gets home. She's got it with her today.
Noticed on that listing it also says
"enhanced speaker system (option UQ3)"
I'll also look at the RPO codes
gooffeyguy
St. Louis
My 2001 doesn't have any identifying "Bose" on the radio or speaker grills.
It does have that amp behind the glovebox and RPO UQ3
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
same thing my 00 had, most likely the subwoofer speaker went bad in back, replacement options are limited but can be done, there is a couple shallow oem type replacements out there, you can remove the old subwoofer speaker and connect any speaker to the terminals to confirm there is still a signal.
gooffeyguy
St. Louis
Yeah, I have some old subs on the shelf in the garage that I can use to test. Just have to figure out how to get to it... Lol
2001 Yukon SLT
2001 Yukon SLT
open the rear hatch, take the long trim off the bottom where the carpet is, then the long piece up top, then the passenger side pillar trim, then you can take passenger side trim out to access the speaker
gooffeyguy
St. Louis
You mean driver's side?
I've replaced the rear hvac resistor pack before and had to do all that for the other side. Was hoping it would be a bit easier for the subwoofer
2001 Yukon SLT
2001 Yukon SLT
ya, lol the other left, same procedure as doing the ac panel just the other side
Da90
Tulsa, OK
I just replaced the sub in a 2001 non Bose Tahoe. After some research I bought this sub. It was definitely $50 well spent. Drop in replacement. No modifications to the sub or factory box. Check out the reviews also. A lot of people using it for the same application and are happy.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/351449146965
gooffeyguy
St. Louis
I wish I knew if it was definitely a bad subwoofer. I found a new GM unit (box and speaker) for $75
2001 Yukon SLT
gooffeyguy
St. Louis
That's an even better price.... Lol
2001 Yukon SLT
gooffeyguy
St. Louis
Well the sub puts out sound, but it sounds real muffled and wimpy/fuzzy. The sound from the rest of the speakers sound real tinny. Maybe the amp is bad. Not sure how to test it. There's no option in the Tech2 menus like there is for my 2012
2001 Yukon SLT
JasonW4141
