285/45/22 dropped pics
Rollout12183
i have a 07 tahoe I’m thinking of doing the Belltech 2/4 kit with 285/45/22 tires with some Escalade reps anyone have pics of this kind of setup?
kbuskill
NE. FL.
Not exactly what your looking for but I run 285/40/22's on my 4/6 dropped Burb...
The 285/40 tire has about a 1/2" shorter sidewall than the 285/45... just FYI.
67RS427
Check out my build thread, that is the same tire I'm currently running... I just removed my BellTech stuff this week and switched over to Tony's 5-6" rear spring and QA1 coil overs up front. The BellTech springs/shocks in the rear kinda suck IMO. I'll post an update when I get it back on the road tomorrow.
http://www.tahoeyukonforum.com/thre...t-outta-hand-really-quick.92148/#post-1099031
**Not sure why most of my pictures are not showing up, I'll have to look into that. Should still be pictures of my truck with that tire and the BellTech stuff... I had drop spindles up front and BellTech drop struts. I started with the spacer in the rear with the 4" drop but I wouldn't use it again if I did the free travel mod to start
Big Mama
Virginia
Here’s a similar drop 2/3 with 305/40/22. If your concern is rubbing you’ll do a little massaging up front but nothing major.
Big Mama
Virginia
But I like your Escalade better. Grill, lights, mirrors, fog lights really make a difference. Not a common color on these but I do see lots of trucks close.
NORCAL SS
SUV SUSPENSION GURU
Check out my page done thousands
Charlie21ny
