Show off your 2015+ leveled Tahoes and Yukons!
K2 Kaiju
The Depths
Pre and post with motofab 1.5" level...
Sent from my SM-G975U using Tapatalk
mike bz06
For those of you running the 2" RC level, does it still have rake? or is it completely level? I know I've ran the 2" RC level on 2 Silverados now, and each time the front is still lower Than the rear.
Dave Legacy
With absolutely nothing in the truck my measurements were 1/4” higher in the rear and it looked nose-high - an illusion. I think it has something to do with the arches, gap, or something.
olyelr
Elk Rapids, MI
No lift kit. This was the resort after installing Strutmaster mag-ride delete kit.
So what was the results? 1”? 2”?
And how did the mag delete go? Our shock are due for replacement and I am looking to go a different route from oem possibly.
Thanks!!!
CMechanical
Kill Devil Hills, NC
Thanks!!!
It raised the front 3" and the rear drop 1/2" so from ground to wheel well is 37 1/2 in rear and also 37 1/2 in front. This was a shock and spring replacement front and rear. Ride is very floaty feel. Also rocks side to side pretty bad when going over bump at a angle. Pulling into driveways est. Believe strutmaster has got the set up wrong for the 2015 and up. Kit was a GC2FB (2007-2012) Was suppose to be kit GC44F (2015-2018). Sales Rep said it the same shocks and springs in both kit. Just the electric bypass kits are different. Working with tech support about getting the front back down to the shock height.
For mag delete they supplied resisters with water tight fuse. Just cut connector off old shock wire in the resister wire hardness. Also just remove fuse for air pump. No warning lights so far.
For now I'm disappointed in kit. It rides better with the wore out front mag shocks. Probably will just go back to mag ride shocks. If strutmaster can't correct. Rockauto has the for around $318 a piece. Total cost around $1300 plus my labor. Strutmaster kit was $737.38 plus my labor about 6 hrs so far.
jackedupZ71
ended up going with 285/60 toyo ats and 2” suspensionmax leveling kit. only rubbing was on right rear inner fender liner, a little heat and massaging and it was good.
olyelr
Elk Rapids, MI
Are those 20” knockoffs of the oem denali 22’s?
Looks good!!
15TahoeLT
Have a part number for the 3/4” rear spacer from RC? I’m assuming it’s not advertised for this application? I’m running a 3/4” poly Daystar. It’s working, but I’m not loving it (deforming a bit).
Shit, I just looked up the order and it's not Rough Country- it's Rancho (part #RS70075). Same deal though it's Polyurethane. I know McBay Performance makes 1/2" and 1" spacers in aluminum but I haven't seen any 3/4".
Dave Legacy
Thanks for clarifying. Looks identical in design to my daystar 3/4” poly spacers. Mine are working fine, but one of them looks a little “smooshed” for lack of a better term and sit on the axle seat a little sloppy so I’ve been looking for a better fit.
Bentley95
