2001 tahoe key fob part number question
adriver
I would think a tuner should be able to turn off the immobilizer if you wanted to just get rid of it. Maybe BlackBearPerformance could chime in. They would know for sure.
Spacido
Saint Cyr les Colons - France
The frequency for the Tahoe EU is 433 MHz and must be given the number of the remote control:
AU8 GM / UTA 15732808
AU8 being your RPO code. You put the picture on the first page. All our European Tahoe are with this code and they all have the same frequency and the same remote control code.
If you have an answer, do not forget to forward the information
Adriver: thanks, I'm going to see the site you're talking about
daol
daol
sweden
awesome, Il order the https://www.ebay.de/itm/Cloning-Gat...896331?hash=item41e8d12acb:g:IIoAAOSwhilbXyjX remote then, since its the same frequency, and it learns from my working remote, so that should work, would be nice not having to fear if this is the day my remote will stop working:)
daol
daol
sweden
exactlly what I thought, at that price its worth testing, I see no reason why it would not work, same mhz, and it learns from an existing remote, so it should be able to copy the signal/code, but I really have no idea, but worth a try
daol
daol
sweden
If your existing remote still works and is just cracked or falling apart, Dorman makes replacement shells with button membrane. It uses your existing circuit board, just have to find the model that matches....
https://www.dormanproducts.com/gsearch.aspx?type=keyword&origin=keyword&q=keyless+remote+cases
I bought a shell on ebay, so that's on the way, just to keep my one and only precious remote safer while Im trying to find new remotes that work, but a shell will not solve the problem with having only one remote, and the risk if it would break, from me dropping it or the 18 year old electronics just giving up:)
Spacido
The problem is not really to find a replacement shell but to find an entire remote control to have a spare.
With US frequencies we find everywhere, but with European frequencies it is almost impossible. We drive with our trucks thinking that this remote can fail at any time and we find it impossible to restart. Worse, apart from reprogramming the computer, the vehicle can remain immobilized for a long time.
When I bought my Tahoe, I did not understand why the seller insisted that there was only one remote ... it's talking to Tahoe owners, Escalade or whatever in France that I understood
daol
daol
sweden
waiting for the remote I found on ebay, hoping it will work, I wish there was an easy way to just disable the immobilizer, like with the press of a button with a computer:p
adriver
Wait, are you just wanting to disable the passlock? Have you tried to turn the key to auxiliary for about 10-15 minutes until the light is off. That is supposed to permanently disable the passlock. You should be able to do this, and then just use the key without any worries about the passlock not working.
There are passlock bypass kits out there, if getting an aftermarket remote doesn't work.
Spacido
there you are interested :boxed: it is necessary to put the key on auxiliary until the indicator "security" goes out? Have you ever tried it?
I get my truck on Thursday night, so far I have the car from work because I have trips. I'll try Thursday night I think, unless Daol can try before.
Do you have a link to these passlock bypass kits?
adriver
I have never tried to disable it, but that might just be a temporary fix without getting a bypass. I had something like this happen years ago on a different GM vehicle, but I just don't remember how I got it fixed.
What you all are talking about is the passlock, and not being able to start your vehicle because you set the alarm, and then if the remote battery dies, you can't disable it. I know some other models had an ignition switch that would break easier and cause the same thing.
There are still ways to get around the passlock if that happens. GM recommends to replace the remote battery every couple of years so it doesn't, (depending on how often you press that button that battery will last more or less).
You should be able to set the alarm with the remote, and then get in with just the key and see if the passlock keeps your vehicle from starting. If it does, then try this method and do the same thing to see if it starts.
daol
daol
sweden
I just tried it, didnt do anything for me sadly, I think it might be a way to temporarily disable it, if your remote dies, but that you have to do it every time, and wait 10 minutes, and there is a risk that the car will just stop while driving, from what I read online. and that there are no simple way of just turning it off.
I got the new remote today, sadly it didnt work.
I found this today, I rather have another remote, but if I cant find one, this should take care of the problem http://www.gmupfitter.com/publicat/bull/bull26.pdf
adriver
Bummer..
https://newrockies.com/ have anyone tried it? they claim that it works, but rather know for sure before I spend 300$
I saw that, its $300. There are (nearly) free ways to do it if you are handy.
If you search youtube for Passkey bypass, it looks pretty easy.
FOUND THIS: (for 1/10th the price)
https://www.sonicelectronix.com/cat...c-immobilizer-bypass-modules-chevy-tahoe.html
(They will ship to nearly every country worldwide). For our friends outside of the US. This is a well known company here in the US. I have bought from them several times myself, and very happy with their customer service. I would call or write to verify exactly what you are looking for, but I think this is it, if you wanted to just disable it for good.
Does this solve the problem completely that you are concerned with? I hope so, I have no clue, good luck with that.
EDIT: I forgot OP is looking for his 2001, and this item is for a 2003-2006.... I think that link may help a few others out. For OP, I did find some similar kits for a similar price on ebay. If you search Passlock bypass Tahoe .. You should be able to find something similar for the earlier NBS, (if this is what you are looking for).
https://www.sonicelectronix.com/cat...specific-security-remote-start.html?from=2959
Perhaps an aftermarket remote alarm, that has the bypass and its own way to start the vehicle.
daol
daol
sweden
yeah, I saw that there are cheapor options, but the reason Im interested in the newrockies one is, Im not that handy, but I looked at the install instructions, even I can do that, = saving money, instead of having a workshop do it for me, it does what I need it to do, without installing extra features, ie remote start etc, and I asked a few other companies, they cant guarantee it will work on my car, since its not a US sold car, but newrockies can, so the way I see it, yeah It costs more, but its easy to install, they say it works on my car, and it would solve the passlock issue, considering that, I think its worth 300$ unless I find out people had a bad experience with newrockies
Spacido
I received my remote control too. For you it does not work, I'll do a test anyway you never know ...
I get my truck back from work, I hope it works.
It's crazy that Chevrolet no longer provides the after-sales service of its remote controls
daol
daol
sweden
just started thinking about something, the issue we are having, is that there are no keys for our frequency, would it be possible to swap the part that receives the frequency to a US part, or would that cause problems in the box/computer in the car?
geekdownrange
Central Texas
Different frequencies are permitted for different uses in different countries. The US remotes transmit around 315MHz. The EU (and Asia I think) transmit around 433MHz - I know you're already aware of the EU frequencies.
315MHz isn't permitted for remote control use in Europe. Beyond the legality, you may run into interference issues attempting to use it.
Spacido
The problem is that we already have interference problems even though our frequencies are EU.
The other day, I joined my sister in another city (she is from Paris) because she wants to buy a Mustang 66, then we made a restaurant before leaving each of his side, and I managed to unlock my Tahoe after several minutes to fight with the remote. We still have the risk of not starting the engine because of this remote.
After the illegal side :rolleyes: The simple fact of putting larger wheels or putting a metal bumper and you are illegal in France :anitoof:
My Jeep is completely outlawed with its modifications. We have a mandatory technical inspection of vehicles every two years with 133 checkpoints on the vehicle. My Jeep is accepted because the controller is a former soldier like me, so it's okay :driver:
Jumpshot12
