ya that's the problem i'm having when the cooling fans are on high there sucking the juice down hard, I was testing the system with basically everything on lights, flashers, both seat coolers, a/c front & rear, wipers on high, rear defrost. lol, the wipers actually just stopped working never had that happen before motor must have overheated, once i restarted they worked again.I'm with ya on this one. I have dual batteries with a reman 160 amp alt, and the big 3 upgrade. Since it's been 97 degrees, If I have both cooled front seats on, the a/c on full blast, and K5L efans running on hi 90% of the time, I see 12V at red lights. It purks up when moving. I know there has to be a way to keep constant amps.
I disconnected the rvc sensor for now and with just the headlights and a/c going and cooling fans on low it was giving me 13.8-14
I might contact the company that programs the bcm's for led's and see if they can do something with the rvc also I thinks it's called "white's services" or something like that I'm sure it's just a google away, but probably have to wait till monday to find out anything
