kbuskill
NE. FL.
Once you do it, you'll realize that you only need one filter. :D
Unless you are me... then that would be about the right amount of oil but still only need 2 filters... although my 2 filters are equivalent to the size of 4.5 of the factory size filters.... so I guess that is just about right for me... lol
St. Louis
Changed the oil (installed the Fumoto drain valve I've had) and rotated the tires, then washed it. We road tripped down to Branson/Silver Dollar City from Sunday thru Friday of last week. Not too far of a trip, only about 500 miles total. Oil life monitor was saying 24% but it's been 5k miles/6 months since last oil change/rotation.
I bought a cabin air filter retrofit kit that's sitting in the garage that I need to install, but it's been too hot here. I almost didn't make it through the tire rotation. 90 degree heat and lifting heavy things don't go together very well.... Lol
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Kee Fuller
las vegas
Sound like me. Going to seafoam my engine and put some cheap supertech oil in it and run it for ablut 300 miles then change the oil to mobile one with the same oil plug. So hot in vegas i want to do the cabin filter mod as well. Just gotta get a dremel, ill do it probably at the end of the summer
2001 Yukon SLT
But it's a dry heat lol! People kill me when they say that. Still hot!!
PG01
Up here to the right
Dont buy a dremel, use a sheetrock knife with a new blade. Carefully scoring around the lines until you break through... unless you want a dremel. I had multiple choices when i cut mine open (dremel, cutoff wheel, etc) but the sheetrock knife worked for me.
bfourman
Indiana
Used it.
Kee Fuller
las vegas
Like a regular box cutter?
Brian12019
