How Can I Soften Suspension on PPV Tahoe
A123
Hello,
I have a 2010 PPV (EX-Police) Chevy Tahoe and would like to soften the suspension because it has a very harsh and has a stiff ride.
I would like to make my ride quality like a 100% stock Tahoe and would like to know what needs to be replaced/changed to do so.
Please let me know if you know anything about it..
Thanks
Swap the struts, coils and shocks for those from a civilian Tahoe/Yukon/Suburban. Some say even those ride a bit firm, although not as firm as the PPV. This would raise your Tahoe about 1.5". If you want guaranteed softer ride and keep your lowered ride height, get Belltech Street Performance adjustable struts for the front and lowering coils and SP shocks for the rear.
Ilikemtb999
Denver
Tires would also make a huge difference in both looks and ride quality.
A
A123
Do the Belltech ride better than stock? Where can I get them and what is the part #?
Also, do have a PPV and have done this?
Thanks
Thanks
I haven't personally ridden on the BT stuff, but everyone says they ride the same as a regular Tahoe or softer. It seems that most say they ride softer. I chose the BT struts and shocks for when I do my drop since I found my Tahoe to ride a little too firm for how I thought it should ride.
I do not have a PPV but as far as the suspension is concerned, it's the same as a LS Tahoe but with shorter and firmer springs and shocks.
If you install lowering springs in the rear (up to 3") you'll need part # 9506 (HERE)
If you install stock civilian Tahoe springs and just want the shocks/struts, you'll need part # 9534 (HERE)
Also, if you install stock civilian Tahoe springs, you may want what is considered to be the best of the best:
Bilstein 4600 struts, part # BSN-24-186926 (HERE)
Bilstein 4600 shocks, part # BSN-24-186933 (HERE)
A
A123
Thank You so much,
I wanted to know don't I need coils for front or rear?
Ilikemtb999
Denver
I have belltech rear springs and they ride soft for sure. I put bags in to help with bottoming when holding any sort of weight and have the free travel mod done.
A
A123
Do you have the stock or height drop springs? Did u buy the same ones as the link above?
Also, what is the "bags"?
Ilikemtb999
Denver
I have belltech 5305 rear springs and lowering knuckles in front.
Helper bags that go inside the coil springs.
Here’s my wife’s Tahoe in question. Used to be lifted.
A
A123
View attachment 224786 View attachment 224787
Does changing rear springs to stock springs make a difference in ride? Which one are the best ones to buy?
Also, Which ones have the best ride: Belltech or Bilstien or ACDelco?
Ilikemtb999
Denver
I have no idea. It had custom lift springs when we bought it then I installed belltech springs. No way I’d have this thing at a Tahoe stock height. I like low things.
Dampers also make a large difference. I have bilstien 4600’s
A
A123
Where can I get Belltech and Bilstien stock ride height springs? What is the part#?
Also, Where can I get Belltech and Bilstien police ride height springs with stock ride quality? What is the part#?
Also, Which Shocks/struts/springs have the best ride: Belltech or Bilstien or ACDelco?
A
A123
Yeah, I would not want to go less than 2" drop in the rears. But my main focus is to improve ride quality..
A
A123
Can I use Belltech rear springs Part #5321 with Belltech Shocks Part #9534 or Belltech Shocks Part #9506?
What is part# for Bilstien rear springs 2010 Chevy Tahoe
Thanks
Ilikemtb999
Denver
You’d have to call or email belltech or just use their website. I don’t think they do stock height things though. Never heard of bilstein springs. They do dampers.
Thank You so much,
The front and rear is already lowered with coils on a PPV- this is why it rides firmer. Well, that and the shock valving. You will need to change the coils to make it ride softer.
I don't think Belltech makes stock height springs. Bilstein for sure does not.
You already have stock "police ride height springs" which, obviously, have a stock ride quality. I thought you didn't like the stock PPV ride quality and this is why you started this thread. :confused:
What stock springs? You want to change your stock PPV springs for stock "regular" Tahoe springs? Different springs will always ride differently.
Pretty much everything has been answered for you in post #6:
JeffK
