Lowering
BigDawg
I have an 03 chevy tahoe that has an 3/5 drop on it but driver side is lower than passenger side, now i've cranked on torsion bar key to see if i could make even but nothing happened. Any help would be appreciated.
Mubarak Mubarak
Dear's,
I have a 2006 Chevy Tahoe 2WD and lowered with Belltech 2/3 and since them I'm hearing the driveshaft vibration and sound.
Any clue about that guys
Maybe your U-joints were really worn and lowering it changed the pinion angle ever so slightly but it was enough to finish them off? It's a factory-engineered link suspension so the pinion angle shouldn't change much at all.
Or do you hear it when hitting harder bumps and the suspension compresses? If that's the case, you may be shoving the driveshaft into the transmission. You'll need adjustable control arms to push the rear end back.
Ilikemtb999
Denver
Dear's,
You’d probably get more action in the nbs section since only 2500 burbs had torsions in the nnbs era
TiGrayMSM
