Engine side cover
denalianyone
NYBlackLade08
New York
This piece rusted off on the passenger side. I’m not sure what it’s called. The driver side cover still seems to be intact. Is it an emergency to replace right away?
PG01
Up here to the right
Exhaust manifold Heat shield
I would put it back on but for now make sure any rubber hoses or wires are as far away fron tge exhaust manifold as possible... if you buy a new one get new bolts. You may have a problem getting the old ones out tho. I would tell you to run without it making sure nothing is too close to manifold hoses wires etc but im sure ill get shit for it.
If you can get a few bolts out, get some washers and put it back on with the washers crushing the shield
jmanson62
Caldwell, ID
It's an exhaust manifold cover. It helps keep the heat lower and away from wiring and hoses in the engine bay. If possible try and get it replaced soon so you're cooking things close to the manifold.
Sent from my SM-G965U using Tapatalk
denalianyone
denalianyone
NYBlackLade08
New York
Thx for the quick responses. My dilemma now is removing the bolts and hoping they don’t break inside. As oppose to leaving it and zip tie the wires away from it.
jmanson62
Caldwell, ID
Hit those bolts with kroil or pb blaster for a few days before attempting to pull em. And if you have the room try a couple of light taps directly on the bolt heads. It may help loosen them up.
denalianyone
denalianyone
NYBlackLade08
New York
Are these common to rust off? If so, replacing with the same garbage doesn’t seem so sufficient.
jmanson62
Caldwell, ID
To be honest I've never seen one fall off before. Are you missing a splash gaurd on that side of the block?
Thin sheet metal lasting 11 years in what I'm sure is a salted area seems like a reasonable life span to me.
jmanson62
Caldwell, ID
Strange to me. My 08 Tahoe has half a splash guard on that side and the cover is a tad on the dusty side of rust but it is solid to the manifold.
jmanson62
Caldwell, ID
You in Snow country? Here in Idaho they dont use salt on the roads as much as say Utah or Wyoming.
denalianyone
denalianyone
NYBlackLade08
New York
gonna probably do this easy fix than tackling the bolts.
denalianyone
denalianyone
NYBlackLade08
New York
Yea NYC roads in the winter are pretty rough.
spectol
