DIY: Make 2015-2017 LS/LT headlights operate like a LTZ headlight (LED as DRL vice low beams)
Tylus
Tylus
South GA
On my 2017 LT the DRL was the headlight low beams.
The LED strip only energized in park, or when the auto lights sensed it was dark enough for low beams to turn on. Then low beam + LED were on
I reversed that with my mod
It looks like with your 2018 units, we can confirm the LED strip is physically different
dvpvic
I would say the same about physically different LED strip. The odd part I find is the behavior of my DRL, low beams aren’t the DRL. Even with my original headlamps.
To make sure I’m clear on this, if I’m in Drive and e brake is not set the low beams should come on as DRL correct? Or perhaps the 2016 doesn’t even have DRL? The build date on VIN label says 12/15
Thanks for any feedback, just trying to figure this out.
Tylus
Tylus
South GA
With e brake set, put in drive. If low beams come on you have the weird DRL
If the LED strip comes on, you have LTZ harness. it may just be a build thing. My old LS was optioned exactly like an LT...minus the leather.
But then your pictures show the LED strip and it isn’t that bright. Put your headlight switch manually to the Running lights. Are you low beams on also (even though shouldn’t)?
Kpwweb
Well I’m new on here just got the wife a 2016 LT well equipped. I was looking up LED/HID options and stumbled on this LED DRL thread and done little research. I had a friend that has a set of 2018 non HID headlamps and swapped them in to see if they will work direct plug and play. Here’s what I found; on my rig DRL seems to be the led strips only. I don’t have any other lamps come on when in gear D/R etc. I then swapped in a single 2018 unit and left one original one. Attached is a pic that shows the brightness difference. I also took 12v directly to each unit and they lit up as the function while on vehicle which shows that’s there’s no funky pwm going on. Not sure if I have some kind of mod. It come from a family that had it serviced at dealers etc so no one did any mods to my knowledge. I have RPO codes X88 and Y86 I think one of these is tied with the DRL option that I saw OP post about. Anyone know what I’m missing? Anyone on here have a 15-17 that could describe how their DRL functions? Because I think I’m just going to keep the 18’ set on and have the brighter LEDs. You can also see a slight color shift towards the cooler spectrum on the brighter LED
It looks like you have an LTZ based on the grill and the way the DRL work?
dvpvic
No I just bought an LTZ grill from eBay and slapped it in. I like the looks of I’d better than the honeycomb one.
bradac
So based on this logic,
I have a 2016 Tahoe LS, if I add a harness to convert the DRL from Low beam to LED strip, and then install 2018 standard headlights, I should have full led brightness as the headlight is on the passenger side in your pic?
bradac
Hey guys, just an update,
I installed the 2018 Tahoe headlights with the brighter LED stripe on my 2016.
With the harness I got from Matt, Which will swapped the standard DRL low beam to the LED, the problem is this doesn’t let the 2018 headlight run at max brightness with this harness.
Whats really interesting, is if I switch the Parking lights on, and remove the pigtail harness from matt, and just connect it directly like the normal headlight I can get Max brightness with the 2018 headlight I installed in parking light mode. This also happens when I remote start the car. However when the car is in drive without the harness it’s just low beam.
My guess it has todo with relays or not sending enough power. Maybe someone could answer this? I know a BCM reporgram would prob fix it, but looking for alternative solutions.
Attached is the photo of my 2016 with 2018 headlight with max brightness with Parking lighting engaged, when I put it in drive just switches the low beam on.
The downfall to using the parking lights engaged, is no auto headlights, having to turn it on and off, and the rest of the parking lights being engaged in the vehicle during the day.
NappyBoy
Kuwait City
dude i willing to buy the harness you made if you could DM a paypal link and how much you need for those and i will give you my address to ship em
cmatt
The light behavior with and without my harness makes sense. On 15-17 models, the headlamp DRLs are ran at a reduced brightness via PWM voltage.
You’ve confirmed the LED strip in the 18+ headlights is different from the older models.
When you turn your headlamps on, do the LED strips dim on the 18+ headlights?
NappyBoy
Kuwait City
d
@Tylus very well done. I actually just built pigtail harnesses that swap these circuits so the factory forward lamp harness doesn't have to be modified. That way it's plug and play and reversible.
I updated the pic with the finished harnesses (taped & wire loom like the factory harness)
Couple questions:
1. You mentioned the Y91 forward lamp harness is larger to allow for more voltage draw. However, the wire gauge sizes are similar across the suv platforms at the headlamp connectors. The only exceptions are for those with RPO 6J7 (for PPV highbeam flasher) and the Escalade DRL circuit. Both are 18AWG instead of 20AWG in those instances. What am I missing? In 2018, when GM began using the LED strip for DRLs on all Tahoes, the main harness change I see is the wire at position 6 on the headlamp connectors only being 18AWG and only describing it as the DRL Control circuit.
2. I also saw where you said the wiring diagram showed the LTZ LED strip being physically different. Can you expand on which diagram and where it shows that? I'm not seeing it.
Getting the LED strip to have the same brightness as the LTZ version is what I've been working on. What I haven't determined yet is whether the LED strip hardware is different on the LTZ or if it's the circuitry/programming on the components inside the headlamp assembly. The parts catalog I can see doesn't show anything about the LED (only HID/non-HID assembly). Like @Kpwweb mentioned, I wonder if it's a PWM control issue where bypassing it with a relay would work. Although, if that's the case, I would think Gen5DIY's $230 LED DRL harness with its relays would address it. They make a point to state the LED brightness won't change. Maybe that's all their harness does, swap the circuits and use the DRL control to activate relays to provide a constant +12v. They even give the same disclaimer on park lamp/headlamp functionality change that you noted. What are your thoughts?
The only other way I'm currently aware of to do this is with three relays. That allows the LED strip to function as DRLs and keep factory functionality with the other headlamp functions. That's the way @73Vetteman did it.
I'm happy to build the pigtail harnesses with or without the relays for those interested. I'll even do the install with the relays if you'll come to me so I can verify the LED brightness. I'm in Mobile, AL.
where can i buy these harness and how much ?
bradac
No, without your harness, it does not dim the LED when headlights completely on,
which is concerning as at night it’s almost blinding to look LED strip when the headlights are engaged, since it’s at max brightness. I’m wondering if there is a wiring solution for this.
When I connect the pigtail harness you provided it will only keep the LEDs dim at in all modes except off, and not max brightness. problems with this is you never get max brightness then.
I’ve attached two photos below, one during the day with remote start without the harness. One at night without the harness (not the max brightness, it’s allot worst in person, like looking directly into a headlight.)
66DF82AD-B00B-4CE1-A1FA-6B42A3C04EF9.jpeg F16B68F1-62D7-416F-A82F-3E5E7A8064DC.jpeg
cmatt
View attachment 226340 View attachment 226341
Agreed. I can see the increased LED strip brightness being an issue for oncoming traffic.
This makes sense as the non-LTZ LED strip in 15-17 models operates in one mode as it only comes on with the park/headlamps and remote start scenarios.
We need to confirm if the strip dims with headlights on for 18+ Tahoe/Suburbans. I would expect it to.
Regarding the wiring, can you grab a pic of the wires present at your factory headlight connectors? Based on the schematics, I want to confirm if there are 7 or 8 wires present.
My concern with a relay is that it may affect the PWM voltage to the strip and not send the reduced voltage to dim the strip.
Tylus
Tylus
South GA
for 2018+ lights on 15-17 models:
the Y91 schematic on page 1 shows the LTZ models control voltage to the LED vice just straight 12v from battery in the -Y91
Maybe install the work-around harness and then put a voltage reducer (technical name lol) on the LED power feeder line? A little tweaking would find the optimal voltage to produce good DRL output without blinding traffic. Then just lock the voltage down at that value. Easiest and simple approach to minimize headaches down the road. Most LED's draw 5v or less for full output.
bradac
yes it does in does dim on the 2018 models, when the headlight/parking light is engaged, I can confirm this. its only full brightness when the vehicle is in drive and its daytime. let me grab a picture
EDIT
Looks like 7 pins on 2018 and up standard headlight assembly
cmatt
EDIT
Thanks for the pic of the headlight plug. Just to confirm, this is the 2018+ headlight?
The missing pin is position 8. It’s a headlamp bulb outage circuit. It may only be on Yukons/Escalades. My Yukon has all 8 circuits.
How many wires do you have at the harness side of the headlamp plug?
cmatt
I’d like for someone to check the Forward Lamp harness connector at the X50A fuse block. It’s circled in yellow. You’ll have to remove the top of the fuse block to access it.
I want to see if there are wires landed in the H2 & H6 positions. If we can power them correctly, perhaps that can address the brightness on the 18+ LED strip.
Eickybobby5050
