Malik112099
Replaced both rear air shocks and the compressor on my 07 XL. Worked perfectly as soon as I started the truck with no errors on the dash. I’m going to buy a lottery ticket.
The_Burban
Fixed my light bar. Installed XB fogs. Installed blacked out grill. The bowtie may stay off; it was painted satin black and is drying.
New plugs and wires (OEM).
Hi-psi
Atlanta, GA
Replaced the starter today. Vehicle has never not started, but a handfull of times would do weird things like stay engaged for a second after starting, etc.
Took the approach of removing the passenger side fender liner and going in from the side over the top of the frame rail. Super easy.
Also picked up a lightly used McGaughy's 2/3 drop locally for a steal today. Probably get that on sometime in the next few weeks.
We will require pics when you do the drop...;)
I LIKE those! Now if there was only a 5-spoke version...
Thank ya!
Technically, there is a 5-spoke version. The Chevrolet cladded wheels have 5 spokes. Their big pain is the center part where the lugs are is a big open cavity so making a center cap isn't so easy. But, I think I saw where people were using center caps from another Chevy wheel and it was a direct fit or just fairly easy to make it fit.
*EDIT*
Here's a pic of the Chevy wheel de-cladded and it has the center cap from the 17" NBS truck wheel:
Link to thread, second post down: https://www.gmfullsize.com/threads/declad-18x8.246753/
The_Burban
Nice but what’s with the passenger headlight?
Have to talk to the previous owner.
I'm looking at new headlights now ... May go OEM .. or I do like the aftermarket but concerned with quality, durability. And then, black or chrome??
Oh, and did an oil change too .. was running AutoRX for a few cycles. Bought a dozen filters, two bites of AutoRX and have been doing shortened oil change intervals.
Thank ya!
*EDIT*
Almost looks like a Mustang Cobra rim.
bfourman
Indiana
I have been chasing a recurring CEL for catalyst deficiency on the Suburban; P0430. I figured I would try a $20 O2 sensor before I dropped big money on a converter. Turns out the offending sensor (B2S2) was hand tight, likely had something to do with it.
The whole job was done in 5 minutes, we will see if the CEL comes back after a few drive cycles. The scanner still shows a permanent code stored, but I haven’t driven it yet to fully cycle it.
R3cord303
Posse In Effect
Oregon Valley
I got my DRLs fixed and changed out my rear diff fluid. Used 75w-140 Lucas full synthetic and a new Fel-Pro gasket. Its a much bigger pain to change the axle fluid on these trucks than it is on my old S10 on the S10 you’re only fighting a sway bar, on these you’ve got the panhard bar and the sway bar in your way- and the spare tire. Oh well. Goter done. Pic attached is the newly functional DRLs.
CHOO CHOO
BackPagePhil
Manheim, Pa
Do your DRLs seem to go out often? Just curious as mine always seemed to. I just stopped putting them in. I always see our gen Tahoe's and Avalanches with one or both DRLs out.
ASG-MikeS
