A) I don't think soSome of those CAI’s generated >25hp gains with zero tuning.
A) I don't think so
To massively oversimplify, I don't believe that OEM intakes are inefficient enough to be starving engines of oxygen such that a $300 bolt-on modification would increase performance more than trivially and with no negative consequence. If it were that easy and inexpensive to do, the car makers would do it.What part of their process do you doubt?
it's pretty well known that CAI does little to nothing at all without other supporting mods such as porting the the throttle body and intake and tuning the computer to take advantage of a little extra air. One thing it does do is change the sound because the OEM intakes are designed to be quieter. Like Will said go take a good look at the unbiased test's that been performed over and over. Even blackbear did testing on all the big name brands and posted results up (along with the requirements needed to make them actually do something).What part of their process do you doubt?
Here's a post about cold air intakes that is not written by someone trying to sell them.
They also show that tunes were required, that is why it shows all the results having KR and etc without tuningThe blackbear tests show 20+ hp gains
The implication of objectivity.But what part of the blackbear testing process do you disagree with?
It's hard for me to take at face value tests run by companies selling the products they are testing. There are myriad ways for a tester to subtly apply his thumb to the scale. Further, I've never seen an objective third party test that confirms the kind of performance gains we typically see from CAI manufacturers and distributors. Although I concede I've not spent tons of time looking.
