ggeorgia
Around last Christmas, I replaced my hoses, reservoir, reservoir cap, radiator, performed a coolant flush, and also replaced the thermostat while I was at it.
This past weekend, I was driving down the highway when I noticed the 'HOT COOLANT' message on the DIC and saw that my temperature guage was nearly at 260. Note that there were no flashing check engine lights or alarms/dinging sounds. I immediately pulled over at the next exit, popped the hood, and noticed the coolant reservoir was nearly empty. I couldn't located any obvious leaks, filled it with a container of Prestone 50/50 dexcool (that I had in the back on-hand), and hobbled on home.
The next day, I went to Autozone to get the pressure test kit and found what appears to be a leak between the waterpump and thermostat -- so I'm assuming the seal on the thermostat failed. I'm very surprised that this is the case considering that it's an ACDelco thermostat (part no. 15-11057) which I purchased from RockAuto. Since it's covered under the limited warranty, I should be getting it replaced free. I have since re-ordered the part from RockAuto -- will return the defective item afterward.
As added insurance, I'm going to add Permatex 22071 Water Pump and Thermostat RTV Silicone. I didn't do this last time, as I was under the impression that it wasn't necessary. Do you guys agree with this?
Does a seal failure with such a new part seem odd?
