PG01
Up here to the right
Unless you put them 5100’s on 1st notch or ‘stock ride height’ I believe you’re gonna have problems getting them to fit with that spacer, as a matter of fact if those are z71 springs, with the 5100’s on stock height, your gonna be higher than you think and your angles are gonna be too much without new uca’s if you’re 4wd.
I like it tho.
The_Burban
I like it tho.
Thanks.. I think?
The 5100s are set to stock.
The spacer can always come out. I don't expect a RC spacer to throw me up too high.
I don't mind a little lift but if anything seems I'll get a level. The rears are also the Moog Z71 HD equivalents with 5100s.
If I need to pull a front spacer or add a rear spacer to level and even a little lift, I'll be very pleased.
Main goal is to freshen up a ten year old, 110k suspension. Looks like a single shock was replaced by previous owner.
Hi-psi
Atlanta, GA
My memory recall and heated seat buttons rattle. Short of just replacing the whole switch panel, any ideas on how to keep them from rattling? I guess I should just listen to my music louder. LOL
are you sure it's not just loose? I think there is a screw or two that hold it on behind the door panel, I am pretty sure there is atleast 1 because when I replaced my peeling door handle I had to swap the switch out.
Hi-psi
Atlanta, GA
Yeah, I'm 99.9% sure it's just the buttons themselves that are loose. I can hear it rattling, take just the tip of my fingers and apply light pressure to the buttons, rattle stops. I thought about maybe some thin slivers of felt around each of the buttons might work. Tighten up the fitment enough to stop the rattle, but still allow non-sticky operation.
PG01
Self stick velcro, obviously the soft side, i use that shit on everything...but then again i get it free
St. Louis
Just noticed today that the passenger side rear window switch doesn't put the window up (puts it down fine) ..... Lol.
My daughter had the window down but couldn't put it up. The drivers switch put it up fine. Guess it's a bad switch??
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
2001 Yukon SLT
are you sure you didn't accidentally hit the button and lock the control at the driver switch?
St. Louis
She could put it down.
Actually that's what I thought at first, then had her try the rear drivers window and she could put it both up and down.
2001 Yukon SLT
2001 Yukon SLT
well if your lucky it might just be the switch on her door then at least there not pricey
ASG-MikeS
