Show off your 2015-2020 lowered tahoes and yukons
Tk59194
2016 rear 2” level on 22s
What wheels are these?
CMoore711
Trailblazer SS Replicas
Also known as TBSS Replicas.
Z28KE
NC
Made some length adjustments to the ride height sensor links and got it close to perfect. Tony’s 2” rear drop and still sits nice with a fairly heavy trailer, but the pump doesn’t turn on under normal conditions (no trailer and just me, the wife and kid). It seems to take about 150 lbs in the rear to kick on the pump, like when my niece and nephew jump in the 3rd row.
Joey.Donatelli
Overland Park
@Z28KE - Your truck looks great man! Do you have the max trailering package? I am wanting to do a level on mine but been told with the auto leveling system it's not possible. You are making me think that I have been misinformed.
Thanks for the help!
Kpwweb
You have misinformation. You can lower (or raise) with max trailering—just need to adjust the end links for the sensors. I have max trailering and have lowered the rear 2”.
gat0r
DFW
^ yup
i have max trailering & am lowered as well.
reach out to Tony (Norcal SS)
he can get you sorted out
Chevy*808*
Took the family around the island the ride was great for been this low and hawaii has some ugly road . It dose rub here and there but dosent bother the wife and kids
Dearmosd
Made some length adjustments to the ride height sensor links and got it close to perfect. Tony’s 2” rear drop and still sits nice with a fairly heavy trailer, but the pump doesn’t turn on under normal conditions (no trailer and just me, the wife and kid). It seems to take about 150 lbs in the rear to kick on the pump, like when my niece and nephew jump in the 3rd row./QUOTE]
What size hitch drop are you using to two with?
cmatt
You’ve got me curious. What is Executive Driving Services? BTW the wrapped window trim looks good.
Staggered 02
The Escalade sitting on Norcall SS drop kit. Thanks Tony for your help and guidance. This was the 4th or 5th mod as I had to wait about a month or so for the kit. But well worth the wait. Window Tint, Hotchkis Sway Bars and Exhaust were done while I waited for the drop kit.
First pic is after installing the drop kit and Wilwoods. The next stop was detail shop for a quick wash.
Next pic is after I had the wheels completed at the powder coat shop, mounted, & installed about 4 months later.
Got-Boost?
TX
View attachment 226231 View attachment 226233
What do you think about the Hotchkis sway bars? Big difference? Are they designed for stock height or is it meant for a full suspension setup?
Staggered 02
Yes sir, I think they are great. Noticeable difference. They are designed for both stock or lowered. I have Hotchkis sway bars on the Escalade, My Crew Cab, and on my Impala SS. Liked them and the quality so much I went ahead and put a set on my G35 Infiniti.
Definitely would recommend. As noted, this was one of the very first few mods.
Found and uploaded the installed pic below
nadroj
I did a 2/4 lowering kit.
The shop did not do the free travel mod as I kept requesting.
I used the double adjustable coilovers in the front and only the oem top isolator in the rear spring.
Is there a way to disable the air compressor without having to adjust the air ride links?
I also did the 16" wilwood front brake upgrade.
Staggered 02
That looks great. I think it's the same drop that I did. Why didn't they do the free travel mod? Hit up Tony (NORCAL SS), he can help you with the compressor delete.
Any plans to upgrade the rear brakes?
nadroj
I don't think they wanted to do the cutting. Maybe i will bring it to a firestone type shop and have it done quickly.
I may upgrade the rear in the future, not sure. I didn't do the drilled rotors though, just slotted
BadDaddy2003
