04ctd
buddy has his drilled at a motel up north while on vacation,
is this pretty common on the plastic tanks?
fairly expensive to replace.
I'm in NJ and I've never heard of this before. The worse that's ever happened, is getting gas siphoned after removing the cap. Hopefully those scumbags got a bath in gas!buddy has his drilled at a motel up north while on vacation,
I don't see why you couldn't just use some plumbers tape (or any type that is gas resistant) and a drywall type plug and cap itbuddy has his drilled at a motel up north while on vacation,
X2.....super is expennnnnnsive.....lolno, but thanks for the idea
$800 in damage to get 80 bucks in gas... Tops...X2.....super is expennnnnnsive.....lol
bad gas was common back thenNot surprising. Has anyone tried to siphon gas from a late model vehicle? It's not easy with the baffles they put in the filler tube. I recently had to drain half a tank of bad gas out of a newer t-bird. I ended up hot-wiring the fuel pump. I couldn't get a hose into the filler tube, and couldn't get the filler tube disconnected from the tank without a lot of work. Thieves don't care about the damage. They do whatever is easy or fast. They're thieves! If it's hard, they move on.
If it happens to me I'll just find a way to install a drain plug in the hole. Hopefully the next thief won't drill another hole. And who knows? There might be a reason to drain the tank one day. Back in the '70s and earlier, tanks came with a drain installed (my '77 Z has one).
What does "Up North" mean? Baltimore?buddy has his drilled at a motel up north while on vacation,
don't move to Texas, they like to use there electric chairAn an ak47 and a chain to drag him across town with the hitch . The ak47 to hAve put the chain on and lock it the hicth chained. Thing s like these piss me off one hard earned money have it stollen. We need stricter laws you steal get your finger cut off steal twice two fingers, that why there so much crime no laws to protect the good people
