Hey everyone,
Been having some cooling system related issues lately and this one I can't quite figure out.
*2004 Chevrolet Tahoe Z71 4x4 FLEX 5.3L Vortec V8 - Mechanical Fan*
This is something I tried to research and clear up before going the next step and buying a new temperature sensor for the block, but failed.
Really appreciate y'all's time
Video to support the story:
Old thermostat:
- Radiator tank cracked and pegged the gauge at 260 <60 seconds before pulling over
- Replaced with OE-style GM3010275 radiator; 34"L x 17.25"H x 1"W (Thickness of core)
- Temperature would not rise past the 180* mark
- Figured thermostat was stuck and swapped in Murray Thermostat 45687 with "OE Recommended Temperature" of 187* (Surprise to me as the vehicle operated around the 205* mark before)
- Filled with plain water and Redline WaterWetter at 1oz per qt in the cooling system
- Burped system by running heat with recovery tank cap off for ~10min
- Maintains fluid level in recovery tank, but shows flow immediately even after cold start
- Vents blow hot to the touch
