Yates's Cadillac adventures
That's interesting about that van WP. It's probably cheaper than the L99 WP, too.
yates ™
yates ™
Resident Apple hater
Iowa
Haven't checked on prices yet but figured it is one that many would never know about but may good a option for some, it also the same one as a 2010 Sierra 5.3 as there was one there. It just worked out we had one laying around. Need to check if it will mess with using A/C if we are able to get that working.
Gonna use a compressor in the stock location or a high mount? I'd imagine there's PLENTY of space in the Caddy for a stock compressor in the stock location.
yates ™
yates ™
Iowa
No idea at this point, iI assume that depends on how far forward we can get the motor which is likely going to depend on the oil pan. It's one of the things we will check when mocking things up. Not if the factory stuff works right now anyways so not high on the priority list but would like to make it work sometime.
Please slow down. Progress on this thing is going too briskly.
yates ™
yates ™
Iowa
Pretty much have one night a week to work on it which results in 4ish hours a week. I said from the beginning I won't be getting this done anytime soon due to time constraints.
I don't understand. You work 8 hours a day which yields another 16 hours a day for actual work :shrug: Your family doesn't need to see you and you don't require that much sleep. Pick up the pace, skippy :crazy:
yates ™
yates ™
Iowa
Lol. I think part of the problem is that I have come to terms that it will not be completed this year so, with it being so nice, it is hard to go over there during the day.
yep. Most projects do take a while so gotta pick away at them as time and money allows :) I'm in the same boat with the dually. Just trying to pick away at it as time allows and trying not to get too discouraged that the progress isn't faster.
I do think you're taking the right approach rather than just throwing the engine in "as is". Going through it a little bit while it's out of the car is the way to go.
yates ™
yates ™
Iowa
After we do a bit more mock up I can degrease the eff out of it and get some paint thrown on so i can start assembly.
NathanJax
Vacation Nathan
Jax, Fl
8 hours? I seriously think after yesterdays sexting he pawns off his work/vbscripts to other people... like you...
...nothing really excites me the way a black block does.
Understood. Coincidentally, I was pondering earlier today what color, if any, I'd paint mine when I pull it to reseal and cam swap it. My logical half says something like a dull silver/aluminum to make spotting leaks easier. Not really into the traditional "Hugger Orange" and the like. May end up with something that matches the body color as a nice compromise.
I painted the GN block red--just because.
Ossipeelake
