Strange electrical/ power issue, clock resetting
TURNz
Yesterday when I left work, I started my 2001 Tahoe and the Factory head unit had reset. The clock said 1:00 and the CD player had lost it's spot. I thought maybe something drained the battery enough to reset it, but it still started ok.
This morning, I left for work and the clock was ok, then I stopped for gas and when I came out of the store, the radio was again at 1:00 and the CD player had lost it's position.
The battery and alternator are both less than 1 year old.
Could this be the radio itself?
I'm not sure where else to check, or what it could be. I had assumed that if power were lost, that it would reset to 12:00, but I was only in the store a couple minutes.
Which is also weird. It wasn't 1:05, as if it lost time and started tracking again. Both times it was 1:00 as if the power just came back on.
This has also happened to my 03 a few times, radio presets and clock are gone. I've yet to figure it out.
TURNz
TURNz
I found a handful of threads claiming similar issues, but they all say their clock resets to 12:00. I don't know if there is significance to mine changing to 1:00. Does your go to 12:00?
It does, but I have a dd.
Big Mama
Virginia
Could it be a bad ground? I’m with you on the clock reset being weird. A bad ground won’t drain your battery but it will cause weird stuff to happen. Try this. Disconnect your negative for a few minutes then go back in and see if the clock says 1:00.
Grind
^This.
Back when I had a British car, notorious for electrical problems, most things could be traced back to a bad ground.
TURNz
TURNz
This morning I turned the key on and the clock was correct. Once I hit the starter, the clock switched to 1:00.
At least now I know it's not because the battery is draining while it's off.
Is your battery weak? Sounds like hitting the starter caused too large of a draw/load on it, causing your click mishap.
TURNz
TURNz
alternator is newer than the battery
Big Mama
Virginia
Also somewhat confirms the ground or as Tony said alternator. I’m not sure if your year had this but the computer monitors batteries and shuts off non-vitals when it’s too low.
CRN_25
