Yes
Friend of a friend built them for me, they're custom so you could do whatever style you want.
These are built to hold 3 10"s, 2 tweeters, and a horn per door.
Probably the cleanest custom panels I've seen made for audio. Most of the time custom door panels with speakers look odd and too busy.
Doug118
My version
the_tool_man
Upstate South Carolina
I noticed more water dripping from the left rear again. So I started pulling the lower door weatherstripping and this happened.
I finished pulling the rubber off, and pulled the "drain plug" out of the door. There was a LOT of water in there.
I'm guessing this is from a bad window seal. I dont see any other way for water to get in there. Any other ideas?
Chrismnj
NJ
Not necessarily bad seal they are not exactly watertight, so it is acceptable for some water to get in the door, just make sure the drain holes are not clogged.
the_tool_man
Oh, and I noticed the rubber seal strip started separating from my new, aftermarket CHMSL after only a few weeks.
After spending what felt like an eternity trying to reattach it, I just pulled it off. I figure it's not really a seal, but probably just to reduce wind noise. I looked at the OEM one, and it seems to be glued on. On this one, it friction fits into a groove. I'll try gluing it. But I think the only way I'll get it reattached is to pull the whole thing off the truck and reattach it on the workbench. Is there a trick I'm missing?
St. Louis
What drain holes? Every hole in the door had a rubber plug in it.
The other three doors were dry, btw.
There is a small drain hole in the corner. It's right above where the seam from the door skin is folded over.
Btw, I removed the rear most plug from each door and kept them out.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
HiHoeSilver
Away!
Chicago
This is totally normal. Conventional wisdom regarding these trucks says to take those plugs and throw them as far as you can.
Chrismnj
NJ
2001 Yukon SLT
I am not really sure about this drain hole at least didn't see it on mine, I meant lose the plugs. like @HiHoeSilver said
Chrismnj
NJ
My house is located right on the water, we get some really bad northeastern storms, wind driven rain gets in to my driver door like crazy more driver side than any other door, I guess because of this window being used the most maybe?
Chrismnj
NJ
Fu$k that!! Only if there's no humidity.
Agree, I am actually buying a condo in that new 17 story building in asbury as an investment, Nice breeze up there and less humidity at this elevation.
BG1988
Always LOTS and lots of water from the TWO mufflers....
enough to fill up a water bottle
Hodmjstone
