Vortec 454/4L80e HD swapped 1999 Tahoe OBS
6.0 Carb Conversion or Stay EFI?
  • Carb Conversion
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
bigfootchiro
bigfootchiro
Largo, FL
Take it for an inaugural ride yet?
Not yet. @Eds_Auto and I went camping up in Alexander Springs for the weekend with his family and my fiancé. Had a blast! All while we wait for the fabrication shop to make up the driveshaft. The material was on national backorder, but luckily they found a supplier that could get it to them in 3 days. It should be wrapped up and on the road by Tuesday or Wednesday.
Still waiting on that damn ds? What material? Aluminum?
Eds_Auto
Sorry for the delay, been silently working in the background on this project. Some of the final wiring is done for the harness, just need to get the transmission connector rewired for the 4L60 to 4L80 conversion but shouldn't be long, I hired a guy that is good with electrical so hopefully tomorrow (3/15) will be test drive day. I have a mobile welder friend here now putting the final touches on the transmission lift block, original design has it sitting too low so we fabbed up this bracket to lift the transmission 3in. On another note, the drive shaft fits perfect, so we are down to the wire on completing this Hoe!
Here's some more eye candy to hold you off:
20190314_151325.jpg 20190314_152535.jpg 20190314_152511.jpg 20190314_161307.jpg 20190314_161332.jpg
Eds_Auto
I may be weird for saying this, but I'm betting 1st gear whine is gonna sound awesome. This engine/trans came from a motorhome, so I think you have a 4L85. Those have straight cut planetary gears, making it stronger, but noisier.
Only info I found on the difference was the number of gears in the planetary, the 85 has 5 and the 80 has 4. Other than that you can identify it by the RPO code, which we don't have access to since the RV is gone now. I agree, being from an RV I bet it's the 85 since it's rated to 18k lbs. Should be able to handle a good burnout lol
bigfootchiro
bigfootchiro
Largo, FL
I have the VIN number
Eds_Auto
I thought about that. I may be able to run it on Advance and see if it shows what drivetrain it had. The RPO codes are specific for an individual vehicle, I don't even think it was there when we had it lol
kbuskill
NE. FL.
You can contact GM customer care on here at...
[email protected]
Send them the VIN and tell them it's a vehicle you own and you need the build sheet/RPO codes.
They are pretty quick to get back to you Mon - Fri.
scottd
