- Joined
- May 9, 2018
- Posts
- 7,079
- Reaction score
- 13,836
Looks like it will fit on that post to me.The TRS battery terminal ends are too small inside diameter. ( TRS & Morimoto, you can do better than that)....
And, I suppose I can attach positive wire to the secondary battery terminal??
View attachment 218035 View attachment 218036 View attachment 218037
I'm confused as to why that's even on the harness.The TRS battery terminal ends are too small inside diameter. ( TRS & Morimoto, you can do better than that)....
Yes that’s a good place to hook it up. No corrosion.Rocketman..... I thought the same thing, looking at the photos.....
But, nope.... "almost" won't fit. Such a clean harness, but I have to modify it.
( Thinking about it...... Maybe drill it out - will work ).....
Also, I can use the battery jumper terminal to connect the positive? ( I would think so .. so I don't have to raise the battery to get to the hot )
Btw this is for the 05 Yukon?
Ok well just let you know you’re in the 2015+ section. Get a lot more questions answered over in our section , the 00-06Yup.. '05 Yukon... The red box is the terminal for jump starts.
( There's a couple other things under the hood, I don't know what they are).... I wish I had a service manual,
But ....for another thread subject... not here.
Ok well just let you know you’re in the 2015+ section. Get a lot more questions answered over in our section , the 00-06![]()
Being lost with youHey.... O5single..... What are YOU doing here??![]()
