Looking for some HID recommendations...
mountie
The TRS battery terminal ends are too small inside diameter. ( TRS & Morimoto, you can do better than that)....
And, I suppose I can attach positive wire to the secondary battery terminal??
Yukon secondary battery contact.jpg Yukon secondary battery contact open.jpg TRS HID battery end.jpg
mountie
Rocketman..... I thought the same thing, looking at the photos.....
But, nope.... "almost" won't fit. Such a clean harness, but I have to modify it.
( Thinking about it...... Maybe drill it out - will work ).....
Also, I can use the battery jumper terminal to connect the positive? ( I would think so .. so I don't have to raise the battery to get to the hot )
Yes that’s a good place to hook it up. No corrosion.
05Single
afraid of the dark
Yup.. '05 Yukon... The red box is the terminal for jump starts.
( There's a couple other things under the hood, I don't know what they are).... I wish I had a service manual,
But ....for another thread subject... not here.
Ok well just let you know you’re in the 2015+ section. Get a lot more questions answered over in our section , the 00-06 :cheers:
dapperdadman
