Preferred Catch Can?
sarneson91
sarneson91
Alexandria, VA
I got the same one Kbuskill got. Will likely put the same type of media material on the inside of the can like him as well.
kbuskill
NE. FL.
St. Louis
kbuskill
NE. FL.
Kbuskill, I'm looking at getting the same type of catch can that you have. Which inlet is connected to the valve cover, top or bottom?
2001 Yukon SLT
2012 Yukon XL Denali
2011 Yukon Denali RIP 5/20/18
Bottom port to valve cover, top port to intake.
The intake creates a vacuum on the can and the oil vapor from the valve cover collects in the lower part of the catch can.
St. Louis
Cool, thanks.
I got my can, but probably won't install it until this weekend. I plan on mounting it in the same area as you, in front of the fuse box in the area a second battery would go. About how much vac hose is needed for both of the runs?
Also, did you cut the 90* elbow out of the hard plastic line on the motor that connects the pcv to valve cover and attach the hoses to it, or just remove the line and attach the hoses directly?
2001 Yukon SLT
kbuskill
NE. FL.
Cool, thanks.
2001 Yukon SLT
It's been a while since I did mine... I want to say 6 feet of hose but maybe a little more or less depending on where you end up mounting it.
Also I can't really remember but I think I disconnected the hard plastic line and ran the rubber hose directly to the valve cover and intake.
St. Louis
Thanks again!
2001 Yukon SLT
kbuskill
NE. FL.
How is that asi catch can working? Is the size and quality ok?
It works great. The quality is decent... especially for the price. It was slightly smaller than I expected but seems plenty adequate for the amount of oil I drain out.
Pepper1700
