Galandorian
I’m confused; a ways back you said you installed the projectors upside down, then you said the high beams activate downward, then the pic I thought was low beam was actually high beam...never mind,carry on...I have no idea what you have going on lol.
sorry, I thought I made the transition clear in that post lol
INITIALLY, the high beams were pointed down, solenoids on the top of the setup
we had to cut the brackets and make it so they were in the correct position
Looks good You're getting there! I went back to my shop today to work on adjusting my lights. When you go back at it to rotate your drivers side make sure you adjust your bulbs hot spot first then do the rotation. Last night mine looked to be out of rotation kinda bad. Today I loosened my bulb holders and moved the bulb around to get that bright circle or hot spot right at the cutoff and 1/3 below. After I got the hot spot close my rotation didnt seem as bad. Needless to say I'vd had enough of headlights for now I'm not blinding anyone so I'm taking a break lol.
Pm me if you have questions about alignment or adjusting the hot spot and shimming your bulbs.
amen to the "enough of headlights for now". pretty much where I'm at lol.
Appreciate the help
I was thinking the same thing. The shield for the high beam should drop down...
However the solenoid wiring should be on the bottom. I'm so confused by his set up.
Also initial pics looked like they were high beams and upside down. But the latest picture looked correct.
I am not sure what's going on
my bad, I thought I had explained that the first few pictures with the solenoid up top and high beams pointed down, were how it was setup initially, and we had to flip it all to make it work
need to work on my storytelling skills
Finally gave her a good bath. Tried shine armor for the first time I was impressed. But I think she is looking good
2004 Z71 Suburban Green I have a few upgrades done.
beautiful truck
I've always wanted a Z71, but around me they seem to cost more than the Denali's and Escalades do!
