Chrismnj
NJ
Quick question, I have replaced the rear view mirror for the one with temperature and overhead consol with garage opener will repurpos the seat folding buttons for something else, it will get cover in my audio thread, but on my mirror I got “OC - open circuit” message so question is how many temperature sensors is behind fron gril? My temperature indicator on gauge cluster works just fine.
HiHoeSilver
Away!
Chicago
Got on EBay link below, not to be an A..hole or question your skills, but if you don't have experience with transfer paper decals I would recommended bring it to a professional, specially the distressed one it has lots of details that are not connected with each other.
Edit.
Definitely apply using wet method, but don't over wet (spray) as the small details will start to slide out of line.
https://www.ebay.com/itm/Tahoe-American-Flag-Decals-Stickers-Vinyl-Chevy-Denali-Gmc-Window-Flags-USA/183630881000?ssPageName=STRK:MEBIDX:IT&var=691074950096&_trksid=p2057872.m2749.l2649
Just curious, but why the distressed? I get the idea, but imo it just looks like the decal is screwed up. Like the look, though.
not sure on the nnbs but my nbs had 2, I've only seen one on the nnbs so far there could be another one hiding somewhere
Chrismnj
NJ
I think I did see extra plug in the grill area when I took my bumper off. hope its not my mind playing tricks on me now.
If I remember correctly on my nbs there was one in the grill and then one lower in the frame/bumper area or behind the grill somewhere on the passenger side, most people don't even know what they are lol, I only noticed the one in the grill on the nbs because I added a truecool and I had to move it so it wasn't behind the transcooler.
Chrismnj
NJ
maybe @Tonyrodz will have some info on it?
maybe is a different part number for second one? and if it is only one why would the mirror show OC
PER rockauto there is only 1 outside temp sensor, it does not show a 2nd sensor or part number, there is only a superseded number. If I understand correctly you added this part from a different year? if so the wiring or programming may also be different, if so then you could maybe add another sensor and wire it up or maybe patch it in to the existing one but that may change the ohm's or something and give a incorrect reading (just guessing). another member added one to his express van but I can't remember there user name at the moment.
Me :D. But the mirror was from an 01-02, non Onstar, and I used only 1 temp sensor. It reads normally, and even says "ICE" when necessary.
Chrismnj
NJ
got if from Ebay it was advertised as 07-13 Tahoe/Yukon
well I have a 2012 and the mirror doesn't show the direction or the temp it's all in the DIC
some trucks have the backup camera screen in the mirror, some are like the one you purchased and some are like mine, I couldn't switch to the one you bought without making changes of some kind either thru programming or wiring
SuburbanPassion95
