Crazycrew's new to the family ride/build thread
C
crazycrew
Vacherie, LA
And that ***** gonna stay that way too! Only thing I may do is put a tip like we had on the burb (corsa tip)
C
crazycrew
Vacherie, LA
Spent $175 yesterday. On a new ******* battery [emoji2357]. Ah well, she starts everytime now.
C
crazycrew
Vacherie, LA
My djm sway bar endlinks showed up Tuesday. I installed them today. Talk about a pain in the dick hole with no help. Hopefully it makes that big ***** sway a little less.
Also removed the 1" spacer, and swapped my 24s from my truck onto the yukon.
I need to get some machine bolts so I can shorten the links more. The ones that come with the kit are definitely not short enough for the spring alone on the lwb.
I have them all the way screwed down and still need at least another 3/8 shorter on the links. I'll go to. Lowe's tomorrow and get some machine bolts to make my own.
C
crazycrew
Vacherie, LA
So, I dicked with the endlinks today. Cut 1/8th off each side of the links and screwed the caps back on for a total length of 2-11/16". That's from center to center of the endlink caps. Probably could've done 2-3/4" cause the rear is about 1/8" lower, but it'll stay that way.
C
crazycrew
Vacherie, LA
[emoji2961][emoji2961][emoji2961][emoji2961][emoji2961]
Drewphil
