norcalboon
Replacing a 2005 Yukon XL 1500 w/ 5.3 3.42 2WD that has been wife's DD and our TV that is used to pull 28ft 7Klb TT 6-8 times per year typically only a couple hours each way with no real mountains, also loaded with 3 kids, a dog and gear. I added a Tru Cool 40K trans cooler, Powerstop K36 HD brakes pads/rotors, 10 ply tires, and use a WD hitch. It tows OK but works hard going up any grades and will wind 2nd gear up to close to 4K RPM's - but temps stay OK, no super long grades typically.
Considering:
2007 Suburban 2500 w/ 6.0L and 4spd trans & 3.73 4WD, or
2009 Yukon Xl Deanli w/ 6.2L and 6 spd trans & 3.42 2WD
Leaning towards the Denali since it will be mainly a DD for the wife, but want to make sure it tows fine too. I'm thinking with the 6.2 and 6 spd trans (I'll add the Tru Cool again) I should be fine. If i was towing more often I would definitely go for the 2500, but prefer the Denali for daily use.
Thoughts?
Considering:
Thoughts?
