Get a catch can before any mods.
M3kanic
This is about 5k miles of oil that didn't make it into the engine. I would consider this a high priority.
donjetman
Ordered a catch can, ball valve, and 3/8" line today.
https://www.amazon.com/Sporacingrts...244&sr=1-3-catcorr&keywords=catch+can+baffled
I'll be doing a rear main seal job soon too :(
Installed the catch can today. Its a nice unit. I'm trying the catch can first before buying a much more expensive new and improved valve cover.
I didn't use the aluminum fittings that came with it. It was too difficult to get 3/8" hose on them. I used plastic fittings. I also installed a ball type drain valve. Internally I added some stainless scrubber material to help drop any liquids out of the air. I mounted the can to the gas spring mount w/self tapping screws and used a wire ty around the drain valve and power brake booster hose to help support the bottom and prevent vibration.
Time will tell?
I added the stainless scrub pad to mine as well and have been collecting about a 1/2 oz. more oil per 5,000 mile drain interval. I'd still like to get that updated valve cover.
St. Louis
Speaking of catch cans, does anyone happen to know off the top of their head the thread size on standard petcock drain valve?
dbbd1
1/8" mpt or fpt ( male pipe thread, female pipe thread)
1/4" mpt or fpt
And so on...
Pick a size, any size.
St. Louis
Mine happened to be 1/4 mpt. I changed out the petcock style to a quarter turn ball valve style. Much easier to drain.
2001 Yukon SLT
2012 Yukon XL Denali
2011 Yukon Denali RIP 5/20/18
donjetman
Do TSB 10-60-01-008M and you may not need a catch can. https://f01.justanswer.com/ebrock63...il+Consumption,+MIL+ON,+Engine+Runs+Rough.pdf
Great news, we did a 2000+ mile trip to Leadville, CO(highest US city-10,152') and back. Now I'm pleased with our Yukon. It used zero oil. It doesn't burn or leak any now. The catch can isn't necessary anymore, because it doesn't catch much of anything anymore. What it does catch smells more like gasoline and is watery like gasoline? Here is a pic of what came out of the catch can after 1200 miles.
View media item 27505
^^^ If it's already installed, I'd keep it as an extra monitoring point. Sounds like your PCV system is now passing what they were originally designed to do- purge combustion blow-by vapors from the crankcase. Maybe the oily residue is from the collected gasoline vapors washing the oil from the hoses? Regardless, it's great news in your case.
donjetman
Good point, I'll leave it on. It could tell me if there's a problem in the future.
08HoeCD
Do TSB 10-60-01-008M and you may not need a catch can. https://f01.justanswer.com/ebrock63/cec66346-04c1-48e0-98a6-74c35af2c84e_2014+Engine+-+Oil+Consumption,+MIL+ON,+Engine+Runs+Rough.pdf
I ran a catch can in my old Challenger and found that there was minimal oil trapped in the can during road trips but much more during around-town driving. I deduced that steady highway driving was very different from stop-n-go driving relative to blow-by dynamics & output.
Yup. It's all about engine loads. The engine sees higher loads during all the in-town accelerations so there will be more blow-by.
bigrhino
l.e.s manhattan,nyc
Drained my catch can today and had less than half an ounce in the cup. While tightening the drain plug, then starting the engine, a hissing noise came from the catch can. I loosened it and then tightening again, same noise. Right now I have put some Gorilla tape over the drain plug as a temporary solution. Is their a way to fix this. Not trying to be under the hood all day in this freezing weather. By the way I have a BlackBear tune.
HiHoeSilver
Away!
Chicago
What kind of can? Some have NPT fittings for the hoses you could retape and reinstall. Some have tops/bottoms with o-rings that could not be seated or split.
93blkongreenpro
All vehicles should have catch cans. It's that simple, really
Makes sense, but the average Joe never lift their own hood to check the vital fluids, nevertheless would they empty a catch can.
Sent from my SM-N950U using Tapatalk
bottomline2000
Dallas, TX
It's reverse thread more than likely. My drain plug is lefty tight, righty hissy lol..
scottd
